Rainier70 wrote:what all do you generally run off of your inverter?
Wookie97 wrote:Since we are on the topic of inverters, What is the thought of installing the PD4050 Mity mini instead of an inverter. Im still doing research but doesn't it do all the above plus charge your batteries when connected to shore Power?
professorkx wrote:Rainier70 wrote:what all do you generally run off of your inverter?
This is your first question to answer, which will determine your inverter size. I want to run a coffee pot so I don't have to start the generator first thing in the morning, which means I need a little larger inverter...
SalsaDog wrote:professorkx wrote:Rainier70 wrote:what all do you generally run off of your inverter?
OR, leave the 120v coffee pot home and use a coffee press.
Socal Tom wrote:I have a cheap 150w inverter that runs a 22 inch lcd TV and a Roku.
dales133 wrote:Socal Tom wrote:I have a cheap 150w inverter that runs a 22 inch lcd TV and a Roku.
Is it a standard modified sine wave or pure sine wave?
