I finally have reached the point where I am ready for some upholstery. I will be attempting to leave tomorrow morning for Salt Lake City, where my sister lives. We will be working on getting cushions made for the bed/sofa and also some matching covers for the angle between the wall and the ceiling.
Since my last update, I installed the counter top on the front cabinet, then painted everything, then installed the electrical distribution system and verified that all the circuits are working as intended. Here is updated photos.
The first photo shows the angle cut on the front of the bed, and how that clears the door entry way, while still leaving most of the bed 6 feet long.
The next one is showing the space between the end of the bed and the front counter, which is 29 inches
This is counter top in front. I will probably put some laminate on it in phase two. For now, it is painted with the same satin polyurethane as the rest of the interior
This is looking back from the door with the bed folded down
And this one is from the bed looking forward at the counter
And the next one is looking forward from the sofa position, with about 5 feet of open space between the sofa and the counter
This is from the front, looking at the bed folded up to make the sofa in the back
And this is a pic of the back of the sofa with the doors open.
I finished off all the wiring. That included converting the tow connector to a 7 pin in front, wiring up two duplex 110v outlets, wiring up two 12 vdc outlets, hooking up all the 12 volt power to lights, fan, and outlets through the power distribution panel.
I didn't mention it earlier, but I am using an Intellipower converter/charger/power distribution panel that works out very well for my application, since the whole panel is about 12" W x 7" H x 5" D and only weighs 6 pounds. It is a 45 amp unit, and includes the charger wizard that uses 4 different charge modes to keep the AGM battery at the best possible charge. It can go from a very low charge to full charge in about 3 hours, but will also never overcharge the battery if you leave your trailer plugged in while in storage. Also, it has a de-sulfication cycle that hits your battery with a little extra oomph for a short period every 21 hours after it is fully charged. That keeps the sulfur suspended in the electrolyte and not on the plates, extending battery life.
Well, time to pack up the tools and trailer and Jeep, and head out for a fun challenging drive in the morning. Stay tuned!
Gil
