7x16 Cargo Camper
Re: 7x16 Cargo Camper
Postby OverTheTopCargoTrailer » Thu Mar 27, 2014 12:56 pm
Hey Mark
Good to hear from you, I found a reasonable welder who also works in Alum
so I got some 3 projects going......
today I'm picking up 5 custom alum solar panel racks, these will lift the panels higher so the heat issue I had before will be solved.
any ideas on how to make them tilt ? all the actuators I looked at are $100 each.....
maybe i'lll just have to use shocks / dampers at first to get 12" or so lift.
with my insulation the 5,000 wall a/c works great even in 100 deg full sun.
Cheers Jerry
Postby Mark519 » Thu Mar 27, 2014 1:40 pm
Hi Jerry,
Gas struts might be useful but it takes some trial and error to get the right size. I need photos of the racks to really think about it. And photos of the actuators so I can see what you want them to do.
Mark519
Postby Al Swope » Fri Mar 28, 2014 6:25 am
Mark519 wrote:Thanks!
Instead of a built in awning I attached stainless steel marine loops to the upper edge and got a 10x15' tarp and poles. It isn't that much trouble to setup since I can easily jump onto the roof by first jumping onto my generator box. Thankfully the box is strong enough for that. Take down is even easier- just pull the rope out.
How is the awning attached tot he trailer? I have been thinking about doing this too.
Al Swope
Postby Mark519 » Fri Mar 28, 2014 7:49 am
Hi Al, I riveted Harken Micro Eye Straps along the top of the trailer and use a tarp with reinforced eye holes. I just thread a rope through the holes basically alternating between eye straps and tarp holes. I then tie the rope off on both ends with a pull knot at both ends so I can snatch the rope out from the ground. It can be set up with a step stool if you don't feel like climbing on top. You can find a bunch of different size tarps on Amazon and I think the poles came from Campmor or similar camping retailer.
Defender sells the eye straps: http://www.defender.com/product3.jsp?path=-1|118|2303373|2303376&id=172696
Mark519
Postby OverTheTopCargoTrailer » Fri Mar 28, 2014 11:04 am
Hi Mark
Here are a few pictures of the new design. I hate those metal poles sticking up on trailers so I made rounded low profile brackets,
the racks will be bolted into the side drip rail & actually sit on the roof.
ZERO HOLES !!! :lol: :lol:
The hinge would be on one side and the shocks maybe on the other end....
not sure I need to mess with that yet :thinking: :thinking:
will do some more testing this summer.
2 small.JPG (149.16 KiB) Viewed 6143 times
1 small.JPG (122.01 KiB) Viewed 6143 times
Postby Tx River Rat » Fri Mar 28, 2014 11:28 am
OTC
Your set up may be a screaming banshee with that amount of gap between the roof and side brackets.
Might be something to check when you just have one installed.
Ron
Tx River Rat
2nd Teardrop Club
Postby Mark519 » Fri Mar 28, 2014 11:38 am
It looks like the rack may be able to bounce - maybe some rubber between it and the roof or maybe you are going to use the super adhesive tape? I think a gas strut could work once you find the right size and power. Seems like it would be best to have one on each side of the panel/assembly so it doesn't twist as much. If you add a center bar on the rack then you could maybe mount a single strut in the center. I guess you will then hold them down in place with a chain or something? The hold down seems like it would also need to be in the center so the panel(s)? don't get a twist. I would be concerned about them shattering. I guess it depends on the size of the individual solar panel(s) and how rigid their frames are. Also when I built my rack I left 1/8" between each panel frame so they could expand in the heat and not jam against each other or flex against each other.
Mark519
Postby OverTheTopCargoTrailer » Fri Mar 28, 2014 11:48 am
TX River Rat
if it don't scream i'm gonna get one
Screen shot 2014-03-28 at 9.37.30 AM.png (195.52 KiB) Viewed 6138 times
Mark
when bolted down there really is no bounce at all, I was planing to put some VHB under the flat section.....
just to keep it off the roof a little. For the time they will just lay flat as I have over 2000 watts, more then enough.
Postby Tx River Rat » Fri Mar 28, 2014 1:01 pm
OTC
A single layer of alum with any crack under it has a good chance of setting a whistle you wouldn't believe when towing up to speed, Dont ask me how I know. :shock:
Ron
Tx River Rat
2nd Teardrop Club
Postby OverTheTopCargoTrailer » Fri Mar 28, 2014 6:33 pm
So I'll have 20 chances :D :D :D 10 on each side :lol: :thumbsup: :thumbsup:
Will let you know :beer: :beer:
Postby Slyhuntr » Fri Jun 06, 2014 5:35 am
Wow! Nice trailer. I see a lot there I'm going to try to duplicate.
MOLON LABE
My build pics. gallery/album.php?album_id=3549
Slyhuntr
Images: 27
Postby CoventryKid » Mon Jun 16, 2014 6:49 am
Great looking trailer and some really great build ideas!
May I ask what the extra cost was to narrow the wheel track and tuck the wheels under the trailer?
Thanks!
Doug
Vancouver Island, BC
CoventryKid
Images: 130
Postby Mark519 » Mon Jun 16, 2014 8:59 am
It was $125 but I think the problem is finding a manufacturer who will offer this option since it changes the design of the frame and uses non standard axles. I got mine through TrailerShowRoom.com at the Georgia facility. I am not sure if they do this at all of their locations.
Thanks
Mark519
Postby rebapuck » Mon Jun 16, 2014 9:36 pm
I know gas cans are generally red. Is the yellow for diesel?
Judy
1966 VW camper
1967 VW singlecab
rebapuck
Postby OverTheTopCargoTrailer » Tue Jun 17, 2014 6:10 am
Everybody knows the yellow is for pee :thumbsup: :thumbsup:
Blue is for fresh water :lol: :lol:
