Another successful night. I had two items planned for the evening. Extend the bed legs so I could mount them and enclose the ramp door spring so I can run my interior lights up to it.
It was raining when I got home, but the radar showed it should end soon. I started on the legs first. Flipped the bed down and measured both sides to see how much I needed to extend them. I cut the cuts noting how much the blade removed as it cut, then cut my extension pieces to the length they needed to be. Clamped them to the table using a piece of thick flat stock assist keeping them straight, checked there alignment and them welded them together.
![Image](http://i118.photobucket.com/albums/o96/pappamodes/Cargo%20Trailer%20Conversion%202014/IMG_20150616_181723518_zpsutxobj8e.jpg)
![Image](http://i118.photobucket.com/albums/o96/pappamodes/Cargo%20Trailer%20Conversion%202014/IMG_20150616_194802660_zpsnbxjzvmc.jpg)
After they were cool I cleaned the bare metal and welds with denatured alcohol and hit them with Krylon crystal clear so they wouldn't rust. I'll paint them some day when the time is available
![Image](http://i118.photobucket.com/albums/o96/pappamodes/Cargo%20Trailer%20Conversion%202014/IMG_20150616_213224278_zps6bblk7oh.jpg)
![Image](http://i118.photobucket.com/albums/o96/pappamodes/Cargo%20Trailer%20Conversion%202014/IMG_20150616_213237554_zpsnccjyboo.jpg)
To enclose the spring I rough cut the vertical piece, scribed it, re-cut, scribed re-cut, etc until it fit the way I liked. I then riveted a 3/4" square aluminum tube to the back of it. Yeah, we rivet wood around here LOL!
![Image](http://i118.photobucket.com/albums/o96/pappamodes/Cargo%20Trailer%20Conversion%202014/IMG_20150616_204345245_zpsf7phixfq.jpg)
![Image](http://i118.photobucket.com/albums/o96/pappamodes/Cargo%20Trailer%20Conversion%202014/IMG_20150616_204350158_HDR_zps5ueeak7c.jpg)
I then traced the curve onto pieces of strapping to make a "nailer" and cut them making sure I allowed clearance for my square tube.
![Image](http://i118.photobucket.com/albums/o96/pappamodes/Cargo%20Trailer%20Conversion%202014/IMG_20150616_202359588_zpsoldsbel7.jpg)
Mounted the "nailers"
![Image](http://i118.photobucket.com/albums/o96/pappamodes/Cargo%20Trailer%20Conversion%202014/IMG_20150616_203145051_zps8eppndrf.jpg)
Screwed the face piece on
![Image](http://i118.photobucket.com/albums/o96/pappamodes/Cargo%20Trailer%20Conversion%202014/IMG_20150616_210508078_zpsmmg3elmj.jpg)
Then measure and cut the bottom piece. Measured the cable locations in the up and down position and cut out opening for them. I riveted this piece to the square tube and them screwed it to the trailer frame just inside the door. This is the finished piece
![Image](http://i118.photobucket.com/albums/o96/pappamodes/Cargo%20Trailer%20Conversion%202014/IMG_20150616_210448799_zpsvodg5esw.jpg)
![Image](http://i118.photobucket.com/albums/o96/pappamodes/Cargo%20Trailer%20Conversion%202014/IMG_20150616_210454977_zpsmgbyj9gt.jpg)
![Image](http://i118.photobucket.com/albums/o96/pappamodes/Cargo%20Trailer%20Conversion%202014/IMG_20150616_210516707_zps2sd5wy5q.jpg)
Just enough clearance to look planned LOL!
![Image](http://i118.photobucket.com/albums/o96/pappamodes/Cargo%20Trailer%20Conversion%202014/IMG_20150616_213555762_zpswjikdsn8.jpg)
Starting to really look like a camper
![Image](http://i118.photobucket.com/albums/o96/pappamodes/Cargo%20Trailer%20Conversion%202014/IMG_20150616_210942225_zpsf7pai4op.jpg)
Before I headed home from work earlier I bent a couple mock up light fixtures in a few sizes copying an idea I saw on these forums.
![Image](http://i118.photobucket.com/albums/o96/pappamodes/Cargo%20Trailer%20Conversion%202014/IMG_20150616_160516094_zpsncdufvit.jpg)
This is how it will come into the spring cover. I will make it a bit shorter, 1 7/8" overall height, to not hang below the spring cover
![Image](http://i118.photobucket.com/albums/o96/pappamodes/Cargo%20Trailer%20Conversion%202014/IMG_20150616_213634825_zpsvvlc2tdp.jpg)
More tasks tonight with help from Vicki!
Adam
