Thanks Martin. That is what I have also and will rip down to 2". I can't seem to find anything thinner than that anyhow.
Sent from my SM-N900P using Tapatalk
flboy wrote:Great idea to paint the AC to blend in. I really like the way you built the mount and etc. for your AC.
flboy wrote:For some reason, I was thinking you already had a Fridge installed? Will that be for when you are plugged in somewhere, or are you going to get an inverter to run off the battery? If you do that, then you can hook your truck up to keep it charged while driving... and then top off the battery at the end of the day with the generator until you get your solar panels installed later. Those mini fridges do not draw much current. My 4.3 CU Ft. draws <60 Watts when running and it does not run continuous.
m.colley wrote: I need to double check but if I remember right the fridge I was looking at pulls around the same running amp draw as the window AC does, somewhere in the neighborhood of 5.5A or about 66 watts.
Thinking about it as I type this I'll probably go ahead and just do it and not even tell her,.
Solar is definitely in the future.
Martin
flboy wrote:m.colley wrote: I need to double check but if I remember right the fridge I was looking at pulls around the same running amp draw as the window AC does, somewhere in the neighborhood of 5.5A or about 66 watts.
Martin
5.5 amps at 12VDC would be 66Watts or ~ 0.6A @ 110VAC. That is about right for the Minifridge... Your AC is probably running 5.5A @110VAC or 605 watts.. Yours is 8000 BTU so this is about right.. The AC will run about 10X of that Minifridge in power. That is roughly what my system does after monitoring it.
flboy wrote:Martin, most will say they won't run on an inverter. Most inverters are modified sine wave type. Get a pure sine wave inverter and it won't matter. That makes a big difference.
Sent from my KFFOWI using Tapatalk
McDave wrote:Hey Martin,
From what I have been able to gather, Pure Sine is for all intents and purposes, indistinguishable from line A/C. The problem with modified sine is that the wave is "clipped" at top and bottom, probably not an issue for most electrical motors, lights and other not so picky items. However, the electronics, control boards, etc. don't like that kind of "dirty" power. The more capable these devices have become, the more sensitive to noise and voltage spikes and drops they are. Now truthfully, I haven't done any serious 'tronics tech work in decades. I'm not even in the same ball park with what they are doin' today, but the fundamentals don't change, I hope. Anyways, my guess is that you and Don are probably more current than I am, so I think I'll just end it here. Must be beerthirty..
McDave
flboy wrote:McDave wrote:Hey Martin,
McDave
Right on McDave. The bottom line is that a pure sine wave inverter is probably better than some utilities.. The modified are a "stairstep" type waveform and inductive motors don't like that. Some power supplies can compensate for them... it just depends.. But that is why a lot of manufacturers of these Fridges will make the caveat.. because they know people will use them like that. You can hear the difference on the motor whine if you compare both inverters ( I have).
Martin, I bought a generic brand of inverter because it was about half the price with the same specs as a Cobra or other recognized name brand. Prices vary so you will have to do some research. The one I have works great and is very clean, runs everything and puts out the full load... the jury is out on the longevity... time will tell if I saved any money. :-)
