Tommy B wrote:BUTYL Tape! I have tons. Check on the one tube of dicor.
Down to $183.00
I think she eased the hammer down. She's pointing it at the floor now.
I should be ok here! I think.
Placing the order now. Will let you know when it all arrives. By Thursday I think but no rush to install. When you have time Don. I will be in touch shortly I hope.
Thanks for you guidance.
I am heading to Buffalo NY on business Thursday and will be back Sunday...I have a off Day Friday August 4 and Saturday August 5. I'd be glad to come over and help you get it all installed and hooked up one of those two days (whatever works best for you) . The whole job should only take 2 hours. Will that work? I have the brackets...
I will draw a pic of what I was thinking for the roof mount..The good thing with your CTC is that there is no ceiling installed yet. We don't necessarily have to hit the aluminum joists or frame.. we can install some wood between joists and anchor into that... I have tons of scraps.. In any case... there are a few ways to do it.. My idea is to install two rails rails that go across the roof in the area before it curves and just far enough apart for the solar cell to span, and then the solar cells screw into the rails. If you go back to my old build and this one, that is how I did it, except my roofs had/have square edges and I screwed the rails into the very edge part of the roof frame. We will only need a total of 4 less than 1/4 in holes since we can install nuts and locking hardware on the rails from the inside. (we can make a trip to Home Depot together the day we install to get the misc. hardware for the rails... should be <$25.00 and I may already have most of it)
You will like having that panel. I will keep your battery topped off and extend the useful life of it when parked for sure and at least extend the usage of it when boondocking with the fridge running so gen time will be down to a minimum when camping (maybe not needed on a real sunny day depending on shade).
BTW, I think we should install in such a way that if you ever decide to buy a second panel ... it will be just plug and play and no additional drilling into your roof (only into rails) or wiring needed except some "Y" connectors you can order on line for <$10.00 and install in 10 minutes. That is literally what I did when I bought a second panel for my previous build when I also bought the second battery.
This is a disease you know... you just have to know when to walk away.
Edit: Tommy, almost forgot.... we need a hole to get the wires in and since you do not have a refrigerator vent... the following is one way and water tight using the same Butyl tape and dicor lap sealant. You may think of another way without penetrating the roof (side or etc..) but the two wires got to get inside to controller somehow.
- Capture.JPG (24.91 KiB) Viewed 1998 times
