Re: Karebru's 7x16 Build Log
![Post Post](./styles/prosilver/imageset/icon_post_target.gif)
Karebru wrote:My employer has several cargo trailers of different sizes. One is a dual axle about the size of mine. When it's empty, it is tongue weight neutral.
It will ballance on the four wheels without the jack touching the ground, and relies on loading to give it tongue weight.
Mine, empty, had plenty of tongue weight. I haven't weighed it, but it does make my V6 Frontier squat a bit.
The weight I've added so far has been evenly distributed. I've done what I could with my camper design to place the heaviest things over the axles, but there will be some added weight right up in the V-nose where the small bathroom will be. My overall weight should be well within capacity, but I anticipate it being tongue heavy.
So... I think my rig is going to need some help for safety reasons, and for a better ride.
A short-armed weight distribution hitch might fit. My exposed A-frame is very short. Only 30 inches along the tubes from the ball to the box.
I guess my other option would be Firestone Ride-Rites.
https://www.realtruck.com/firestone-air-bag-suspension-kits/R181688P2017Y451MA.html
Years ago, I put them on an F150 that I used to tow a heavy boat, and I was very happy with the difference they made.
Right now, I'm leaning towards the air assist bags.
Any thoughts?
That is a lot of trailer for that truck and you want it all level for tow. I'd definitely have a weight distributing hitch with anti-sway... you cannot go wrong with that and will have the hitch adjustment and etc. to level it up..... but the Airbags are also a good thing to have and have their place. My WD hitch will balance it all out and the anti-sway is priceless IMO, but the load on the rear springs will cause some bounce and related handling issues that the hitch cannot resolve. I have used Airlift bags before for this reason and they were a great solution. I just put some on my F-150 for my new CTC because of bounce. I have not hooked up the CTC yet... but will be doing that soon. I'd recommend both. When you are towing a trailer at highway speeds, too many things to go wrong and to have it all handle properly in an emergency and/or poor conditions... you cannot put a price on that.
I just put these on:
![Image](https://uploads.tapatalk-cdn.com/20180908/1b345ef21aadb372b81d32950500cadd.jpg)
