8ball_99 wrote:Before you get to far have you tested your AC on that inverter? There are several threads floating around here on it.. Some things will work on MS inverter some things won't.. One guy just tested 3 differen't Window ACs with one MS inverter. Some worked better then others. I know you said you didn't care if the AC didn't last long. But you probably dont' want it louder then normal or using more power then its suppose to. If I remember right you only have one battery onboard? If so I would not run it very long at all for the test.
Ok 8ball
You gotta stop messing with me.... you almost gave me a stroke with all those ideas about that guys cheap ass Harbor Freight $100 inverter .....
The bottom line is that his comparison with that cheap inverter is a apple to orange comparison.....
window ac will work fine with a good quality "USA" made MSW inverter
I finally got around to a test of the 500 watt ac & she runs great, can't tell any difference really with a short 10 min test...
I did have a glitch after connecting the shore power to the inverter,
as I disconnected the shore power to the inverter with the ac runningCRAP....everything went dark... Double Holly crap
NOW WHAT ??? .... its 8balls FAULT - Did I just fry a $5k solar system ?Well it turns out that I only had a 75 amp fuse on the battery & the a/c knocked out that fuse - There goes $15.99
However the 100% fully solar powered dream AC - OTTCT is still alive and wellI did however notice a small screw up & could have ordered this model that is PSW Magnum MMS-1012 1000 watts for only a couple of bucks more
http://www.wholesalesolar.com/products.folder/inverter-folder/Magnum-MMS1012.htmlEven with 1 panel 50% shaded at 4:30 pm - the solar panels were still pulling 200 watts...
Next step is to try test again at high noon "SOON"
Now that I also found my new "BUDDY ERIC" the electric engineer .....
dare I say
"I have a dream" of kicking the solar up to 6 x 255 ie
1530 watts maybe ?Now I know you guys might think by now
I'm "a little Cucu in the Cabesa" but since I'm still working I sorta feel like I have a moral
obligation to help lubricate the economy with my little drop in the bucket spending SPREE !!
Last week I saw a house for $2.9 Mill 3,500 sq ft sold in 1 week , 2 offers for CASH -
My friend just dropped $95k on a new 200 sq ft kitchen - I'm a charlie lunch bucket compared to those guys
now those guys are CRAZY in my mind
http://overthetopcargotrailer.blogspot.com/
