Engineer Guy wrote:.
Consider removing the plywood walls. Install Poly Iso Insulation at R-8/inch. Or, as I plan to do, install an inch of it between the steel or aluminum frame braces. Then, install another inch of it over that, screwed into furring strips, for an R-16 wall. You'd 'lose' only a net inch of space on either side. Heat rises, so install 3" or so of Poly Iso Foamboard in the ceiling IF space permits. One rule is to install ~2x the insulation in the ceiling as you would in the walls.
