Hot water question?
Postby Trackstriper » Sun Apr 04, 2010 6:51 pm
jwhite wrote:Thanks again for the replys,I bought a small electric water heater off ebay and when I hooked it to a water hose I could not get it to heat water so I contacted who I bought it from and they said I need a
(water flow tap )to make it work?
is this a valve that slows the water flow?
What kind of water heater did you get, point-of-use or tankless? The problem as I see it is that the electric tankless units require a ferocious amount of power, for a short duration, to make them work. You would also have to factor in their temperature stability if you are thinking shower. On the other hand, a tank type unit will be temperature stable and will require less juice at any given moment...just over a longer period of time. I did check and the GE 2.5 gallon tank type does use a standard screw-in element which should be able to be replaced with a 1000w unit. For a quick shower that should be enough. I have a 5 gallon homemade water heater (400w Hott Rod heater element driven by a 750w inverter) in my van that simply heats the water to whatever temp I wish to take the shower in, usually about 105-110 degrees, and it works just fine with a low-flow shower head...throttled down. The pump pulls directly from the heater so I don't have any further temperature control, but the 5 gallons of water is very ample. I could take two back-to-back showers to clean off, or one lingering shower. No problems over the past ten years. I would think a 2.5 gallon unit running at 140 degrees would get the job done for you when mixed with some ambient temp water. This would get the job done for one person.
Trackstriper
Images: 38
Postby jwhite » Sun Apr 04, 2010 8:20 pm
THe water heater I bought off ebay dosen't work and I have been going back and forth with the people that sold it to me demanding they send another one,they asked for me to send photos of how I hooked it up twice I am about to tell them I am going to post a negative rating if they don't send another one.
I only paid 40.00 for it and it was shipped from Europe I also had to buy a travel plug before I could use it
The Brand is a Hoter NEW ELECTRIC SINK INSTANT TANKLESS HOT WATER HEATER 2KW.
it looks like they have quite a few different type water heaters,I think I just got a bad one.
I have used one of those solar bag type hot water showers and it worked pretty good,if you don't over fill them they will get pretty hot and will stay warm for quite a while.
I may just do that this summer and learn more before I buy real water heater.
jwhite
Images: 46
