WesGrimes wrote:This is very interesting. I was planning on getting a 5000btu unit, and assumed it would cause ice to form inside while it was 100 outside.
Anyone else have a report card for how their 5000btu window units perform?
lonerider wrote:
If there's alot of humidity that will make it worse inside!! You will get up in the morning and everything will be damp!!!
8ball_99 wrote:Window AC has two different inputs. You have the return in the front then you have the vents on the side that pull air in and exhaust it out the back to cool the condenser. My guess is his vent in the picture is for the vents in the side.. This is a very bad idea.. You are pulling cooled air from inside and exhausting it outside This also just pulls more hot air into the trailer. The face of a window ac should be sealed in the trailer and the side vents and rear should be outside. They really won't work any other way. BTW those pics are not the OP. I think his unit is installed like it should be?
