What is the preferred/recommended method for cutting the blue/pink foamboard insulation? The local Lowe's guy didn't seem to have a clue.
Thanks,
Don
Trackstriper wrote:Don, here's an update. This week I've been working in the Boston area, a little ways from home base. After dinner tonight I cruised the Home Depot and Lowes stores to see what you were looking at with the 6.5 R-value. Both stores had a lot of polyisocyanurate insulation, I suppose folks in this area have to pay attention to their insulation like you do. There was only a small selection of extruded polystyrene and very little expanded polystyrene.
Now, Lowes had 1" thick Dow polyiso 4x8 panel that had silver foil on one side and blue foil on the other....rated at R-6.5 (Home depot had a similar product that was silver foil on both sides). Maybe that's what you got, and if so, well done. The polyiso foam tends to be a light tan/off white color and usually has a foil face on both sides to slow degradation. The pink and blue extruded polystyrene have color throughout the foam, that's how you can tell the difference readily.
What I have found interesting as I've been in different parts of the country is how the box stores will favor one type or thickness based on local demand. I couldn't find any 1" board stocked in Atlanta, but it is a standard item in South Carolina...so I bought some there while working on a project at Clemson University. When I made my earlier comment, I'd forgotten that the market varies a lot, and I'd assumed your blue board was the extruded material.
d30gaijin wrote:What is the preferred/recommended method for cutting the blue/pink foamboard insulation? The local Lowe's guy didn't seem to have a clue.
Thanks,
Don
Trackstriper wrote:Folks will suggest different ways. Of course it can be cut with any kind of saw but that will leave "plastic sawdust" around and that stuff can get stuck to everything with static electricity. And it's a pain if it gets in you eyes.
