mskobier wrote:Russ,
Excellent on getting the insulation in the walls. If it were me, I would concentrate on getting the ceiling insualted as soon as possible. That is where the most heat gets sucked out of the trailer. That aluminum roof makes an excellent heat sink. If nothing else, if resources allow, at least get some insulation pressed in between the roof ribs over the area where you sleep. Every little bit counts. Especially on the ceiling. The front has a plywood wall, that will isolate the living spacew from the cold a little bit. Even a cople of bread bags stuffed with old rags stuffed in the space at the top of the front wall to block the air flow will help some.
If your CT has the rounded top corners, you will find that the 1" foam will be difficult to "mold" to the curved area. I used two layers of 1/2" sheets in the corners of mine. Made installation relatively easy.
Mitch
Thanks Mike on the idea of the corners. I was concerned about that. I will do a little at a time. This spot where I am parked is open field and I had everything tossed out and worked on the walls first. Then everything else is accessible while I still am in it. Had to sleep on a hard floor Thursday night (not good sleeping. Those days of rough camping are WELL over!) but I slept well last night. Here is a photo of the Thursday tear down.
[/img]
I can't believe I had so much in there. Notice the open field I am in. Notice the stuff inside that still needs to come out as well as outside. I've slimmed down some. The trip home will be a little lighter.
Look what I lost and found from over a year ago. Sweet!
Tight fit. Had to put some pressure on the sides to get it in.
