Xtremespeed wrote:I ended up using 2" for the shower p trap reduced to 1 1/2" and 1 1/2" for the sink. I connected both sides with a y and and then reduced a standard 3" outlet to 1 1/2" to fit the y. I bought one of the caps you suggested with the garden hose fitting. It will serve as my cap when traveling and when the ct is not in use and if the garden hose connection works, great, and if not, I can remove the cap and use a standard sewer hose. It all turned out pretty good. I just wish there was a way for the shower p trap not to hang quite so low, but I installed my shower directly to the floor, so the entire p trap is below the floor. It's not real low, but I wish it was above the bottom of the frame. I did manage to keep the 3" outlet tucked up in there. You you have to reach up under there to get to it, but I don't have to worry about knocking it off, and whenever I need to access it, there will be no water flowing out since I don't have an onboard tank.
bdosborn wrote:Fits on a standard bar sink drain and has a garden hose connection on the downstream end:
Camco 37420 RV Flexible Camper Drain
roadinspector wrote:Thanks for the info!!I see a hepvo going in my CT.
bdosborn wrote:roadinspector wrote:Thanks for the info!!I see a hepvo going in my CT.
Do you really need a backflow preventing valve? You're not hooking up to a sewer and there shouldn't be any gas coming back from your portable grey water tank. I've never had an issue with smell coming back up my drain and I connect to a portable grey water tank.
