Fresh Meat....16x7x7
Re: Fresh Meat....16x7x7
Postby roadinspector » Thu Aug 02, 2012 10:10 pm
Progress has been put on hold for a few days. Heat wave is kicking my butt. It was 107 today. Temp forcast is 108 tomorrow.
Earnest
Dadgum it! I cut that board 5 times and it's still too short!
2001 quad-cab Dodge Cummins 3/4 ton camper special, 16x7x7 CT work in progress toyhauler, 01 HD Ultra Classic, 98 HD Heritage Softail, 88 HD 1200 Sportster. viewtopic.php?f=42&t=51510
roadinspector
Images: 127
Postby roadinspector » Sat Aug 11, 2012 9:00 pm
It was 75 deg this morning so I was able to get some work done. I finished insulating my ramp and started on removing the 3/8 plywood walls. I put some of the thin factory trim strips between the roof and the frame to help prevent heat transfer from the roof. What is your opinion on that? The strips will help and there isn't much room for anything else to fit. It was 100 deg by noon so I called it quites. Maybe I can get some more demo done tomorrow afternoon or evening. Nothing to really show with pictures yet. Most everybody knows the mess of demo work and has seen the guts of a bare CT.
Earnest
roadinspector
Images: 127
Postby roadinspector » Tue Aug 21, 2012 9:27 pm
I finally got the 3\8 plywood out of the trailer. The aluminum in the corners turned into a challenge. They used what appeared to be torx T20 but it would not fit. T15 was too small. The internal teeth were sharp where a torx is blunt. I ended up using a small center punch. :x I would drive it in with a hammer and turn at the same time. This would loosen it enough to turn it with visegrips. I later found a m-3 allen wrench will bind in it enough I think it will work. Haven't tried it yet so I'm wondering if anyone has had this problem. Anyway, I got the floor cleaned and ready to epoxy paint. Humidity is supposed to drop by Thursday so I can get it done.
I removed 3 windows from my donor trailer. Sure glad I have this trailer to rob. Sure going to save some money having this.
Any input would be greatly appreciated.
Earnest
roadinspector
Images: 127
Postby ksbiker » Wed Aug 22, 2012 7:06 am
Try a #2 Robertson (square head) I had problems with mine until if found out it is a double cut square drive that makes it look like a Torx.
ksbiker
Postby bigbendhiker » Wed Aug 22, 2012 7:56 am
ksbiker wrote:Try a #2 Robertson (square head) I had problems with mine until if found out it is a double cut square drive that makes it look like a Torx.
I have a set of Kobalt (Lowes) bit drivers and mine also took a square head driver attachment to remove the screws. It works fine without stripping the heads of the screws.
Scott
bigbendhiker
Images: 28
Postby roadinspector » Wed Aug 22, 2012 9:43 am
BIG HELP! :beer: That makes complete sense now that I think about it. I ran across those once years ago but I've slept since then. I got a couple of square drive but I'll swing by Ace on the way home and pick up a couple #2 drivers to make sure. These got to be stainless screws so my drivers go before the screw does. They laugh at a chisels, punches and visegrips. Thanks again!!
Earnest
roadinspector
Images: 127
Postby roadinspector » Mon Aug 27, 2012 1:28 pm
Update: i got the floor and ramp painted with the Rustoleum epoxy paint Friday morning early. Kinda trailer related but IS vacation related, I replaced the stator, rotor, voltage regulator, primary chain and adjuster on the bike after I painted the floor. Vacation isn't the same if the bike isn't running, besides it is my daily transportation. I think the epoxy paint will serve its purpose well and will know with time how it holds up on the road. I will be watching for cracking. Saturday I started insulating. I got the roof insulated and started on the walls. Now I will read more on window installation and get that going. I haven't ever done it before so I am very grateful for the post that goes into detail about this. I can tell there really isn't that much to it but as most folks, I am apprehensive about cutting holes in the side. No room for error, just room for a change in interior design if I get it in the wrong place.
Once again thanks everybody.
Earnest
roadinspector
Images: 127
Postby bc toys » Mon Aug 27, 2012 1:59 pm
The main thing about window installs is cutting between the steel studs and not over cutting the corners. It good if you can make templete to mark the holes out use ten snips or angle grinder and go slow. Its also a good thing to install pop rivets in the trim threw the side of trailer don't want to be going down the road and see window go flying or run screws all the way threw walls. I have been keeping a eye on this build you are doing great job. Oh ya use a good sealant between the window and trailer.
bc toys
Images: 42
Postby DTCOOPER » Mon Aug 27, 2012 3:23 pm
When cutting the hole for my exterior receptacle, I found teh plasma cutter is a dream come true.. I originalyl wasn't going to install any windows, due to me being reluctant to cut the skin with a saw.. But the plasma set on about 15 amps, makes as smooth of a cut as my steady hands will allow ! I now plan to install a small porthole window on each side up pretty high. (To avoid peeping toms. LOL)
Because I have a constitutional right to, that's why!!
2007 Tundra Tow Vehicle
2004 Road King for riding
Kawasaki mule, 4 wheelers, and other toys for playing!!!
DTCOOPER
Postby roadinspector » Mon Aug 27, 2012 9:33 pm
bc toys wrote:The main thing about window installs is cutting between the steel studs and not over cutting the corners. It good if you can make templete to mark the holes out use ten snips or angle grinder and go slow. Its also a good thing to install pop rivets in the trim threw the side of trailer don't want to be going down the road and see window go flying or run screws all the way threw walls. I have been keeping a eye on this build you are doing great job. Oh ya use a good sealant between the window and trailer.
bctoys,
My trailer is not one of the better built rigs. The studs are on 24" not 16" as prefered. Two of my windows are 24" and will fit between the z studs. The only trimming on the stud is I need to do is remove the interior portion z that the 3/8 plywood attaches to. Are you saying It would be better to shift the window one way or the other and remove a portion of a stud? Then frame it out or would the way I got it directly between two studs be better. That seems better to me but you have more experience with this than me. I have 3/4" selftapping stainless screws to attach the windows to the frame. I also have RV Butyl Tape for the sealer. It has worked well in the RVs I have been around for almost 30 yrs. It was used on the windows I just removed from my donor trailer & it was still plyable and doing its job. Hadn't thought about tinsnips. THANKS. I was going to use my saber saw. I like that idea better.
DTCOOPER wrote:When cutting the hole for my exterior receptacle, I found teh plasma cutter is a dream come true.. I originalyl wasn't going to install any windows, due to me being reluctant to cut the skin with a saw.. But the plasma set on about 15 amps, makes as smooth of a cut as my steady hands will allow ! I now plan to install a small porthole window on each side up pretty high. (To avoid peeping toms. LOL)
DTCOOPER,
A plasma cutter would be nice to have. I run a po-man operation here. As far as peeping toms go, I really feel sorry for someone that is desperate enough to peek in on an old man that has a .45 1911 on his belt or under his pillow and a saiga shotgun in the corner. ;)
Earnest
roadinspector
Images: 127
Postby roadinspector » Mon Sep 03, 2012 9:47 pm
Well I cut a 24"x35" hole in the side of my CT. The window actually fit the hole! :applause: It has been 100+ lately. The build is going slow. Hopefull tomorrow I can get the window installed after work. Depends on the temp. Thanks guys for all the info & assistance.
Earnest
roadinspector
Images: 127
Postby roadinspector » Fri Sep 14, 2012 11:21 pm
I will try to make time to get some pictures posted sometime this weekend. So far the CT is now insulated, windows in, and the floor painted. Hopefully I can get a lot of work done this weekend. I will be putting up 1X4 length ways down the roof to support the insulation and give something better to attach my ceiling material to at a later date. Put the plywood walls back in, install the 110-12v converter, breaker box/fuse panel, lights and a switch that I pulled out of my donor trailer. It will be in a temp location for this trip. I am scheduled for vacation in two weeks and just want it to have some basics. I will still have lots to do later when I have more time. I will be using an oil bath radiant heater if the nights get cold. It won't be getting warm enough to need an AC unit. Thanks for everyones help from all the CTs that are here. Whether you commented or not, I learned something from everyone. :beer:
Earnest
roadinspector
Images: 127
Postby roadinspector » Sat Sep 15, 2012 9:18 pm
Finally got some :snappy: up loaded. :thumbsup:
97879 97880 Epoxy floor.
97881 97882 97883 97884 Windows installed :guzzle:
97885 97886 Insulation completed and walls going back in. :designing:
97887 Electric port installed. :thumbsup:
Tommorow I will install 1x4 supports for the ceiling insulation and run my electric. :worship:
Earnest
roadinspector
Images: 127
Postby roadinspector » Sun Sep 16, 2012 10:24 pm
I finished my walls and got the 1x4s installed on the ceiling this afternoon. I didn't get the electric ran but it shouldn't take long (famous last words) since it is basic for this trip. No need for battery install yet, camping area has electric. I am using the 110-12v converter & breaker/fuse box out of my donor trailer. Wiring needs for this trip is just 3 110 outlets, 1 for converter, 1 for refrigerator and another to keep the wife happy. I am using 12v lighting. 1 exterior and 2 double and 1 single bulb interior. I am basing my build around what I can rob from my donor trailer. It may not be 100% the way I prefer. But I have to keep my building OCD in check and remember I am on a serious budget and use what I have to work with. It will serve our purpose very well and be comfortable.
It was a good weekend. I'm tard!! Gonna have to go back to work tomorrow to get some rest.
Earnest
roadinspector
Images: 127
Postby Smartin436 » Sun Sep 16, 2012 10:31 pm
Lookin Good!!!!!!!!!!!!!!!! :thumbsup:
Smartin436
