pvangel wrote:^^ I have the same water heater^^ Used it for the first time this weekend and it worked great!
How does that Mr Heater work? Does it smell when on?
hankaye wrote:gregert12, Howdy;
As far as the drain for your water system ... you can add a 'T' between the
tank and the pump. run the line out the floor of the trailer with a shut-off valve.
That's how the set-up in my RV works. Or you can install a seperate outlet into
the tank and run the drain from it...
hank
the tank and run the drai from it...
hank
roadinspector wrote:hankaye wrote:gregert12, Howdy;
hank
Hank is right about how to drain the tank. Mine was set up where the second port on the bottom of the tank was the drain valve and they had a valved line line before the pump like I previously posted to draw antifreeze instead of water. One thing people forget about is the water lines. There is two ways that I know of to protect them is to either pump RV antifreeze thru the lines or blow the water out with air. Your going to use a tankless water heater so this part would not apply to you. But for those that have a tank like mine. I advise a by-pass kit so you don't waste antifreeze filling the tank after you drain it.
Earnest
Not sure what your problem is with the Reese system,
Good pix. But what exactly is the problem ???
hank
