orcadigital wrote: I do not have a battery, so do I connect the negatives to a grounding bar and then to the frame or grounding bar and to the negative battery terminal connection on the WFCO?
MtnDon wrote:orcadigital wrote: I do not have a battery, so do I connect the negatives to a grounding bar and then to the frame or grounding bar and to the negative battery terminal connection on the WFCO?
I would connect the negatives all to a common point; a buss bar. Then a connection from there to the power source.
Sort of ditto on the positives, except they would go to a fuse or breaker for however many circuits you would divide things into and then positive lead to the power source.
Hope that helps.
orcadigital wrote: The outstanding question would be if I ever add a battery, do I run the wires directly to the convertor, or ground the battery negative also. Question for a later date though.
Thank you for all the help!
