questions about solar wiring,,, shunts & fuses etc!
Re: questions about solar wiring,,, shunts & fuses etc!
Postby Shadow Catcher » Wed Nov 13, 2013 7:56 pm
I made the same mistake, a 66 cell high voltage 185W panel had to get a Morningstar SunSaver MPPT controller which would handle the better than 70 open circuit volts. It, in full shade puts out 35V.
Unless you have more than 800W coming out of your panels there is no point in going with 24V, some one will correct me if I am wrong.
You might also want to consider 2 6V in series like www.rollsbattery.com up to 1300AH and bullet proof.
Postby OverTheTopCargoTrailer » Wed Nov 13, 2013 8:38 pm
Woh doggie are you now telling the guy with 460 watts to get 1300 AH Batteries ?
Now that's insane :cry: :cry:
Postby Shadow Catcher » Wed Nov 13, 2013 9:16 pm
OTTCT, Note the "up to"! There are many lesser batteries.
Postby OverTheTopCargoTrailer » Thu Nov 14, 2013 10:37 am
Because IMHO his 624 AH batteries are way overkill for 460 watt panels.
Postby eamarquardt » Thu Nov 14, 2013 11:59 am
OverTheTopCargoTrailer wrote:Because IMHO his 624 AH batteries are way overkill for 460 watt panels.
I'm not sure a "camper" needs 624 amp/hours worth of batteries. Perhaps some enlightenment is in order.
Gus
eamarquardt
Images: 150
