bdosborn wrote:
You might want to check and make sure they don't use lead solder or something like that if you're going to run potable water through it. It's probably fine but it's something to think about...
JUST use PEX
OverTheTopCargoTrailer wrote:lrrowe wrote:So are you saying that you basically have two tanks of hot water radiating warmth to "heat" your trailer.?
YES ... I can heat up to 80 gallons or more to 140 deg...
for example with 20 deg at night, 40 gallons at 120 will work to keep my trailer at 75F
Lower temp = more & hotter water, or maybe refill smaller 20 gal tank during the night![]()
MtnDon wrote: Of course most folks don't drink water from their water heater; or do they?
MtnDon wrote:Appreciate the links to the controls. However, my desire is to try this as a low budget affair. The non digital old thermostats use no power when idle. They simply close a circuit. I like that too.
My ideal heater would be a Propex. IIRC, they are 93% efficient. They cost more, much more, than I want to spend at present. $700+
