davidshourd wrote:lrrowe wrote:David,
I like it. Welcome aboard.
Can you share how you mounted the awnings to the CT and what is your experience with rolling them back? Easy, hard?
Bob
the back awning is just bolted onto the flat plate along the back of the trailer. these ARB awnings have an extrusion along the back that fits a 1/4" bolt head. allows the bolt to slide left to right but keeps them all in line up and down. then a little foam tape and some sealant to make sure everything stays water right.
The side awning was much more of a challenge with the radius of the roof. the way these awnings fold out they pretty much need to be plumb in the vertical or the extension arms that fold out to catch the end of the awning do not fold out level to the ground. so on the side I added a piece of 1/4" aluminum angle that had a 1" horizontal leg and a 5" vertical leg. this hit the radius of the roof/wall to a NEAR plumb condition. that was through bolted to the roof cross members and then thoroughly sealed up on the top and both sides. from there the awning was simple drilled, tapped and bolted to the 1/4" aluminum from within the enclosure of the awning. VERY stout and very weatherproof.
these awnings are not bad to roll back up. I had a 6' on a previous camper and that is about the biggest a single person can do. so the 4' is no problem. the 8' on the side requires two people until I maybe come up with a single person system for wrapping them up. once in a roll it fits up in its pouch and has three Velcro straps that keep it in place while you zip it shut.
ARB makes awesome products and these awnings are no exception. hold up great there wind, rain and sun. and with their ability to be quickly deployed it provides you with a little shelter as soon as you pull into camp.
Thanks,
I understand what you did and also found several "how to's" on Youtube. I think this awning is a strong candidate for my "must have list". If I go with it, I think I will think about some system where I drive with it inside the CT and then quickly slide the back plate into place when I get to a camp spot. This would help keep the sides smoother for traveling.
I liked the way one Youtube installer made a swinging rig so the awning could travel and be set up on the side and then if desired, swung to the back if he wanted to use it over his Bard Doors.
This link is a video for a similar mount (towards the end of the video). But there is another one that was a DIY rig, but I cannot find it now.
http://www.youtube.com/watch?v=PXaqWF8xnfA
This is a duplicate post that I cannot see how to delete.
Bob
