Security torx bit?
Re: Security torx bit?
Postby Prototear » Thu May 08, 2014 1:30 am
I once had the same problem and was pointed to this set of security bits at Harbor Freight. This set of many bits is only $6.
http://www.harborfreight.com/33-piece-security-bit-set-68459.html
It has various sizes of the hollow point Torx bits and many other unusual ones.
First Build: viewtopic.php?f=50&t=57021
Prototear
Images: 412
Postby lrrowe » Thu May 08, 2014 8:06 am
I like these last two posts. If Greg M's hollow bits would work, that is good. Then again, Prototear's simple slotted screwdriver idea also has a lot of potential.
I am going to get a box of those bits at HF for my own use.
Bob
Bob
lrrowe
Images: 439
Postby absolutsnwbrdr » Thu May 08, 2014 8:32 am
Prototear wrote:I once had the same problem and was pointed to this set of security bits at Harbor Freight. This set of many bits is only $6.
For $4 more, you get a bunch more... http://www.harborfreight.com/100-Piece- ... 68457.html
I have this set, and its very handy, even as storage for standard bits. As the standard bits get chewed up, you can replace them with quality ones. :lol:
Zach
Coming Soon...
absolutsnwbrdr
Images: 412
Postby Al Swope » Mon May 12, 2014 6:23 pm
Neither set has bit that is close ti big enough :x
Al Swope
Postby MtnDon » Mon May 12, 2014 7:03 pm
MtnDon
Images: 24
