Skin screws coming loose.
Re: Skin screws coming loose.
Postby hankaye » Fri Sep 12, 2014 9:19 pm
Mike S, Howdy;
Lots of different applications that use "wet" bolts/screws/rivets. By "wet" I mean
dab some on the threads or dab a dollop in the hole just before installing the
fastener of your choosing and then wipe off the excess. We even used to spray on
sealant on the F-14's as a corrosion protection layer in the painting process.
hank
hankaye
Postby CGRotorhead » Fri Sep 12, 2014 9:39 pm
hankaye wrote:Mike S, Howdy;
Loctite Red ... used to use it on H-3 and H-60 Helicopters when I worked on them (it was specified in the maint. manuals).
Skins were 0.030" regular #2 Phillips screws ... great stuff. Those helicopters vibrate a lot more than most folks think...
hank
X2 on this we use it also on the coast guard 60s that I work on. But you could also just use some pop rivets as well. We just put them in wet with sealant then put a little more on the head to seal it when me make skin or structural repairs in which you can't get to the back side to buck a standard rivet
   HE WHO LIVES WITHOUT DISCIPLINE, DIES WITHOUT HONOR.
CGRotorhead
Postby Mike S » Sat Sep 13, 2014 8:45 am
So with Red Loctite, the procedure would be; unscrew the screw all the way, coat the threads and the head with loctite, put some in the hole, and re-insert screw. I think I'll give it a try on one section of the trailer.
2013 7 x 16 Charmac Stealth CT , deep in conversion process :)
http://www.tnttt.com/viewtopic.php?f=42&t=66412
2011 Toyota Tundra, 4x4, Double Cab, 5.7L
Mike S
Images: 54
Postby hankaye » Sat Sep 13, 2014 11:53 am
Mike S, Howdy;
Mike S wrote:So with Red Loctite, the procedure would be; unscrew the screw all the way, coat the threads and the head with loctite, put some in the hole, and re-insert screw. I think I'll give it a try on one section of the trailer.
Only need a drop on the tip of the threads, it will spread out over the length as it winds it's way in.
Sometimes less is more .... On the next section of trailer try a dab of silicone in the hole then screw
the fastener back in and wipe off the excess silicone. That way you can evaluate the 2.
hank
hankaye
Postby Mike S » Sat Sep 13, 2014 1:10 pm
hank
Great idea! :applause: :thumbsup:
Mike S
Images: 54
Postby highdesertranger » Thu Sep 18, 2014 10:34 pm
Loctite is not meant to be used on sheet metal screws. highdesertranger
highdesertranger
