Electric Heat
Re: Electric Heat
Postby GerryS » Sat Oct 04, 2014 9:28 pm
Don't discount smaller heaters. This little one did very nice at last years gal gathering....low 40s.... And a Honda should run it with no problem.
http://www.amazon.com/Lasko-100-MyHeat- ... nal+heater
GerryS
Re: Electric Heat
Postby Prem » Thu Oct 09, 2014 7:07 pm
Gerry,
I'm in. I just bought one. No more propane for me.
Thanks.
My goal...
...is to live in a trailer.
Prem
Images: 144
Re: Electric Heat
Postby hankaye » Thu Oct 09, 2014 8:08 pm
Howdy All;
hummmmm wonder how many cubic feet of space it will keep warm ...
hank
hankaye
Re: Electric Heat
Postby GerryS » Sat Oct 11, 2014 6:44 am
Let me know how you like it.....we use a 1200, but that because we have one side door open and a side tent....the dogs sleep there. It's so sad to wake up and see them shivering....yes, they've got a dog bed...and blankets....
GerryS
Re: Electric Heat
Postby VijayGupta » Sat Oct 11, 2014 7:50 pm
as an aside, I found a nice little heater that I got and have been using while we're out in the last week.
(Relatively) small, very quiet (quiet fan mode or no-fan convection mode), little clearance need. 2x750W heater elements that you can run either or both at once, not too expensive, thermostat, timer (if wanted), shipped to the house for free.
http://www.homedepot.com/p/Crane-1500-Watt-Convection-Portable-Heater-with-Timer-and-Fan-White-EE-8068-W/203545311
If you are small spaced and well-insulated, they also have a 400W version that can stand alone or wall mount.
VijayGupta
Re: Electric Heat
Postby lrrowe » Sat Oct 11, 2014 8:00 pm
Do these Honda equivalent generators have remote start? If so, I could see the routine of running the gen. to warm up the trailer and then shutting all down when going to bed. Then in the AM, before it is time to actually get up, roll over, hit the remote start and have a warm trailer before you get up. Lazy, yes! Defeat the purpose of roughing it, yes. But at least I can think about it.
Bob
lrrowe
Images: 439
Re: Electric Heat
Postby rowerwet » Sun Oct 12, 2014 6:05 am
For heating with a generator as power, look into the pelonis disc furnace, they are more efficient
rowerwet
Images: 521
Re: Electric Heat
Postby abqlloyd » Sun Oct 12, 2014 9:34 am
The Honda inverters don't have remote start. The Onan 2400 will remote start as its a purpose-built RV generator. More $$$.
abqlloyd
Re: Electric Heat
Postby lrrowe » Sun Oct 12, 2014 9:36 am
I didn't think they did. And I was only dreaming out loud. Just saying how nice that could be.
Bob
lrrowe
Images: 439
Re: Electric Heat
Postby abqlloyd » Sun Oct 12, 2014 10:29 pm
I've seen some hacks for the Yamaha version.
abqlloyd
Re: Electric Heat
Postby Rainier70 » Mon Oct 13, 2014 6:34 pm
Another heater that can be run at 400 watts or 800 is an Optimus infrared heater.
http://www.amazon.com/Optimus-H-5511-In ... red+heater
Rainier70
Images: 244
Re: Electric Heat
Postby chukarchaser » Sat Nov 22, 2014 8:06 pm
I run my generator like I stole it. Run them hard and often. Letting them sit around and babying it when you do run it will eventually cause problems. Ask any generator repair shop
chukarchaser
Re: Electric Heat
Postby professorkx » Sat Nov 22, 2014 9:03 pm
I am looking at one of these heaters:
http://www.homedepot.com/p/Econo-Heat-4 ... /202882716
I plan on using a base board thermostat to control on/off.
anyone have any experience with these?
professorkx
Re: Electric Heat
Postby GuitarPhotog » Sat Nov 22, 2014 9:44 pm
professorkx wrote:I am looking at one of these heaters:
They don't get very good reviews. But for heating a TD, they might work OK. 400W isn't much heating capacity, most room heaters are 1000W or more.
<Chas>
:beer:
GuitarPhotog
Images: 55
Re: Electric Heat
Postby khigh » Sun Nov 23, 2014 4:54 pm
I've got a 400/900 from Harbor Freight. It's one of the disk infrared kind. The advantage of that is that it heats what it's pointed at, so if you set it on low and pointed it at your bed, it might do the trick, though I don't have any specific experience using it in my CT. I use it in my basement office that doesn't get QUITE enough heat from the central HVAC
http://www.harborfreight.com/lawn-garde ... 62313.html
$22.49 with the ubiquitous 25% off coupon
The 900 setting is the top power - they don't combine like a lot of them - just the two settings.
khigh
