John61CT wrote: ... Do these units do anything special to act as a power supply for House loads, and still keep
track of declining current acceptance rates to the battery?
hankaye wrote:That is exactly what they were designed for and from my experience (8 years of RV full-timing), they do what they are supposed to do, and do it very well.
defjr333 wrote:............ I only know the inverter/ charger somehow does "look" at the battery and incoming current state and adjusts the charge current and voltages accordingly. It is a 3 stage charger .......
MtnDon wrote: The charge amps slowly fall while the voltage is held constant. Some,up-scale units may be able to be programmed to terminate absorb charge by the amperage. Amperage input to the battery falls during absorb due to the nature of how lead acid batteries act. The final third stage is float which is both voltage and current controlled.
