Coating/Sealing Factory Floor?
Re: Coating/Sealing Factory Floor?
Postby flboy » Wed Jul 25, 2018 12:07 pm
DANJR wrote:Thanks! How did you seal up the underside after installing the foil backed styrofoam in between the floor frame pieces? Did you put another piece of sheathing on the bottom of the trailer sandwiching the insulation?
The insulation is literally styrofoam with foil back. If cut correctly, it presses in tight, and any gaps filled with expanding foam. I glued it to the floor with liquid nails and ran a bead of foam around the perimeter not so much to seal, but to create a ledge to retain the foam if the glue were to let loose.
Really no opportunity for water ingress.
Don (Flboy)
https://youtu.be/6_-8cVdWUIA
https://youtu.be/MUcMM86LA2g
flboy
Images: 378
Postby McDave » Wed Jul 25, 2018 3:13 pm
I saw a forum member coat the inside flooring with a "Rhino Liner" type coating. It looked pretty darn nice and should be about bulletproof. Might just do both sides if the OSB is strong enough for the loads you will be hauling. Probably not cheap, but 0.75" marine grade plywood is spendy too.
You could also use sheets of coroplast to "seal" the underside. That is how the big travel trailers do it. It can be removed to service plumbing, elect. etc. and could protect the insulation or undercoating/ bedliner spray.
https://www.zoro.com/zoro-select-corrug ... /G5896969/
https://www.homedepot.com/p/Coroplast-4 ... /205351385
McDave
McDave
Images: 412
