Some folks need to not just assume things.
The debate about running with the propane "on" to run a fridge is a long one.
YES, it is illegal to have an open flame at a fueling facility within "X" many feet of the pumps.
YES, it illegal to have the propane system "ON" while driving through a Tunnel and you will have to
detour around some that go under a body of water even if the system is "OFF".
Generally propane appliances have a fail-safe built into the system so that IF the flame goes out
the propane is shut-off. The best example is the "Sail Switch" that is part of the furnace. Those
of you that have a RV style heater in your builds will notice that when the thermostat activates the system
to generate heat you will hear the fan kick in then 5-15 seconds later you will hear the burner ignite. Well
during that time the sail-switch is sensing the flow of air, not enough and you don't get ignition. (Google;
sail-switch in RV furnace),
The vented door (air inlet), for the RV fridge is designed to operate with the wind blowing past it or directly at it.
Think about it a moment. Do the fridges blow-out when it gets windy ... NO. I've been living in an RV for the past 10 +
years. It gets windy out here in the High Desert (no wind breaks). Never had to re-ignite the fridge.
Please show me where " It is illegal to be running on propane while driving in most jurisdiction, "
My emphasis
What about Propane powered vehicles???
hank
