I am confused on what you mean by cycling the inverter on and off means. The inverters are usually on and in standby until a load is turned on. Can you explain more?
Trebor English wrote:My Harbor Freight inverter has a switch to turn it on and off. I opened it and attached a pair of wires to the back side of the switch. That pair of wires goes to the temperature controller relay. If the inverter switch is on the inverter runs. If the inverter switch is off the relay controls the inverter. That eliminates the need to switch the DC input to the inverter. The inverter has a big capacitor on its input. The high current on connection will eat relay contacts.
