A 12 ft. FEATHERLITE conversion
Re: A 12 ft. FEATHERLITE conversion
Postby Prem » Sun Dec 21, 2014 9:46 pm
:Flippin Burger: Lithium Ion BBQ for trailer camping:
:cigar:
My goal...
...is to live in a trailer.
Prem
Images: 144
Postby lrrowe » Sun Dec 21, 2014 9:49 pm
That will not make a Happy Camper for sure! :cry:
Bob
lrrowe
Images: 439
Postby Prem » Sun Dec 21, 2014 9:52 pm
If you just vent the flames and the smoke effectively, you could heat the whole trailer with it.
:o
My goal...
Prem
Images: 144
Postby lrrowe » Sun Dec 21, 2014 9:55 pm
Isn't there a following that says that every setback presents an opportunity?
Bob
lrrowe
Images: 439
Postby Prem » Mon Dec 22, 2014 1:56 am
Yes, if one actually survives a catastrophic setback like a lithium ion battery bank fire in a CT.
Darwin Awards will likely be handed out in the afterlife for those who don't.
:worship:
My goal...
Prem
Images: 144
Postby lrrowe » Mon Dec 22, 2014 10:10 am
This sort of makes a case to tread slowly in this area and maybe stay with my Trojan T105's until more is proven on these batteries.
Bob
lrrowe
Images: 439
Postby Prem » Mon Dec 22, 2014 2:44 pm
Nature applies minimal-but-sufficient standards in all lifeforms. Bones are hollow for weight reduction. Trees only grow as tall as their roots can support. A CT that gets heavier and heavier is ultimately just a mass of overkill and overly complex function caused by runaway ego, over spending and an engineering attitude that more and more is always better. Are we camping/living for peace of mind or to impress the neighbors with size and quantity? If it's the latter, my 35 ft., dual fuel, 4 MPG bus was "the bomb" with 150 pounds of batteries, 300 watts of solar, 72 gallons of water, 33 gallons of black water, 33 gallons of gray water, 200 gallons of propane (carburation fuel) and 66 gallons of gasoline. 9,000 lbs. on the front axle, 13,000 lbs. on the rear axle. That was so OVER THE TOP that I danced a jig the day I sold it. I'm still dancing.
:D
My goal...
Prem
Images: 144
Postby Prem » Wed Dec 24, 2014 4:19 pm
My goal...
Prem
Images: 144
Postby Prem » Wed Dec 24, 2014 8:05 pm
To you all :EXP
____________________________________________________________________________________
My goal...
Prem
Images: 144
Postby hankaye » Wed Dec 24, 2014 9:13 pm
Prem, Howdy;
Merry Holiday and a better New Year.
hank
hankaye
Postby Hiflyer » Wed Dec 24, 2014 9:23 pm
Prem wrote:Nature applies minimal-but-sufficient standards in all lifeforms. Bones are hollow for weight reduction. Trees only grow as tall as their roots can support. A CT that gets heavier and heavier is ultimately just a mass of overkill and overly complex function caused by runaway ego, over spending and an engineering attitude that more and more is always better. Are we camping/living for peace of mind or to impress the neighbors with size and quantity? If it's the latter, my 35 ft., dual fuel, 4 MPG bus was "the bomb" with 150 pounds of batteries, 300 watts of solar, 72 gallons of water, 33 gallons of black water, 33 gallons of gray water, 200 gallons of propane (carburation fuel) and 66 gallons of gasoline. 9,000 lbs. on the front axle, 13,000 lbs. on the rear axle. That was so OVER THE TOP that I danced a jig the day I sold it. I'm still dancing.
:D
I see what you did there ;)
Hiflyer
Postby lrrowe » Wed Dec 24, 2014 10:48 pm
So you are saying, less is more?
Bob
lrrowe
Images: 439
Postby Prem » Wed Dec 24, 2014 11:55 pm
:thinking:
I'm saying that too much is a bad thing (clutter, complexity, weight, expense). It's the age-old needs vs. wants, fad vs. utility decision-making process that needs to be applied.
Only you can determine what is minimally optimal for you. Maximally optimal would be the U.S. Defense Dept's inventory of stuff. And watch out for "mission creep."
http://i.ytimg.com/vi/BizSfbrzn2Y/maxresdefault.jpg
http://www.prepperforums.net/forum/attachments/strictly-bug-out-vehicles/2209d1373342621-bicycles-buggin-out-back-up-highwaybike.png
My goal...
Prem
Images: 144
Postby Prem » Thu Dec 25, 2014 12:05 am
:thumbsup: Thanks Hank :EXP
My goal...
Prem
Images: 144
Postby OverTheTopCargoTrailer » Thu Dec 25, 2014 4:14 am
No chance of runaway fire here
