Spring Break in the Jemez of NM; it snowed a little, the snow melted, the sun shone, we had a couple of shirtsleeve afternoons followed by 32 degree nights, we thinned more trees, and I now have all the firewood needed for
next year, cut, split, and stacked.
Now back to the CT... Some other things had to be done around here today but I did take pictures of what I accomplished before deserting for spring break.
The shower pan ready to be glued in place. PEX plumbing supply for the future sink in the nose area, conduit for some 120 VAC electric and one for the sink drain. Not much room for all that under / behind the pan...
![Image](http://i139.photobucket.com/albums/q305/djmbucket/Cargo%20Trailer%20Conversion/DSC_0959sml.jpg)
The wall between shower pan and bed will be installed as soon as I pressure test the plumbing supply lines (tomorrow?)
Closer up view showing fresh water tank and fill line, vent line, drain and pump line...
![Image](http://i139.photobucket.com/albums/q305/djmbucket/Cargo%20Trailer%20Conversion/DSC_0960sml.jpg)
The receptacle is 120 VAC from either shore power, generator or the inverter. The PEX that goes vertical is for the shower and the vertical gray conduit is actually a waste tank vent line that will penetrate the roof.
Next are the two golf cart batteries on their slider and showing the 2/0 welding cable cables. Black is positive and white is negative; similar to white being neutral in an AC system. I don't worry about the colors on the battery interconnect cable. DC master disconnect on the leading edge of the tray...
![Image](http://i139.photobucket.com/albums/q305/djmbucket/Cargo%20Trailer%20Conversion/DSC_0962sml.jpg)
The other electrical major components...
![Image](http://i139.photobucket.com/albums/q305/djmbucket/Cargo%20Trailer%20Conversion/DSC_0964sml.jpg)
In the center is the Iota DLS-55 is a charger / converter I had had for many years. It has seen a variety of uses over time. FYI, it is a multi stage charger; bulk, absorb, float and a timed automatic equalize. 55 amps maximum output. Copper buss bar for the chassis ground connections. The black box to the left is an AC automatic transfer switch. There is a shore power inlet on the left rear outside corner. That input line connects to the box with the red face plate (on the left). The inlet also connects to one of the inputs in the ATS. The orange wire connects the second ATS input to the inverter 120 VAC outlet. The inverter is another item I've had for several years. It is a Xantrex PROwatt SW, pure sine wave 2000 watt. The data cable on the PROWATT is for the remote control which will be located up front in the counter / sink area.
Another view showing the cabling and the nailer plates to keep me from driving screws through the cables. FYI, the generator can not be operated in its storage space. I may at some future date build the carrier / storage rack I have planned. That would mount on the exterior of the left rear door once the reinforcement rack and bars is made. he idea is to be able to lock it up and be able to operate by opening the dust cover. So far just an idea...
![Image](http://i139.photobucket.com/albums/q305/djmbucket/Cargo%20Trailer%20Conversion/DSC_0965csml.jpg)
The positive and negative cables connect to some copper buss bars. A bolt through the plywood wall supplies a connection point in the battery chamber. Hidden behind the rear frame crossmember is a 250 amp fuse. The white and red 8 gauge wires are the master DC feed to the front of the trailer. That has a fuse off the buss bar as well. A second fuse from the buss bar connects forward along the bed framework to the 12 VDC RV water pump.
