Its sort of mine!
Re: Its sort of mine!
Postby Padilen » Fri Sep 02, 2016 8:23 pm
Today the outside outlet GFI decided to quit on me. I had another on hand. I've found I always need to have one extra. I'm going to wire a few more things. So I bought a 14-3 extension cord. Oh and a cheap TV! Everyone asked where was my window so I got one. Now it's where's your TV. Now some other changes and ...
Padilen
Postby hankaye » Fri Sep 02, 2016 10:01 pm
Padilen, Howdy;
Gotta be careful about them TV's ... Once they get connected work slows down to almost a crawl
if your not careful ... :roll:
hank
hankaye
Postby Padilen » Sun Sep 04, 2016 6:58 am
My friend gave me a used shelf/ counter and folding wall brackets. It's warped bad so I made some supports. I like it!
Padilen
Postby Padilen » Wed Sep 07, 2016 6:56 am
So with a "new" shelf comes a Remodel! Still planning, it all out. Portable AC moved back and shelving about 8". Opening up some storage in vee. I was just moving to get wiring ideas but liked it. More aromatic cedar too! I'm going to add a ladder to loft bed.
Padilen
Postby flboy » Wed Sep 07, 2016 9:22 am
Be careful... I was talked into painting one room of the house a while back, and it all ended with painting everything. Same thing could happen here. LOL :-)
Sent from my SM-N900P using Tapatalk
Don (Flboy)
https://youtu.be/6_-8cVdWUIA
https://youtu.be/MUcMM86LA2g
flboy
Images: 378
Postby Padilen » Wed Sep 07, 2016 9:41 am
My house has need to be painted since 04 ! Think the paint is still good?
Padilen
Postby Padilen » Sat Sep 10, 2016 8:03 pm
I hope to take my CTC to the sugar bush to use as my base while I'm cutting firewood ! Ok well I'm going to try to cut & split my own firewood, see if my body can do a few hours. I had my last day of PT. I mentioned my plans to my PT therapist. She suggested trying an hour or 2 morning then rest then 1-2 in afternoon. Ok that's another lie. She said since I was going to do it anyway I should try splitting up the work. (No pun intended).
Padilen
Postby Padilen » Fri Sep 16, 2016 7:24 am
Been busy so I've got nothing done. And it looks like my free wood isn't free anymore, so no base camp needed. I winterized my moms trailer, she's been to busy to use it. I added air bags to my pickup yesterday. They aren't necessary for it but are for me. I have an issue with 4x4's that bump curbs and sag with a lite load. So I lift them. But finically I can't right now. But for less than 100$ I got air bags for the rear.
Padilen
Postby flboy » Fri Sep 16, 2016 7:33 am
I put airbags on my old pick up truck and they made a huge difference when towing anything substantial. Without a load however, it was necessary to let some air out as the stiffness and bounce was very noticeable to me.
Living in Florida, I never give much thought to winterizing things... but I guess it is getting to that time of year for you folks up north. Stay warm!
Don (Flboy)
flboy
Images: 378
Postby Padilen » Fri Sep 16, 2016 8:16 am
flboy wrote:I put airbags on my old pick up truck and they made a huge difference when towing anything substantial. Without a load however, it was necessary to let some air out as the stiffness and bounce was very noticeable to me.
Yep 67 in my house right now! High's today are going up near 80 that's high for us this time of year!
The air bags are a "first" for me. I usually have 3/4 ton or more pickups! I aired them last night to 10. I haven't drove it with air yet. I put them in then rushed to Dr appointment. And returned some lights that didn't work out for my CTC. Was a good idea just too cheap of lights. When I got home I aired them to test then aired them to 10lbs- unloaded, haven't driven it since
Padilen
Its sort of mine!
Postby Padilen » Mon Sep 19, 2016 9:35 am
Some pics of updates ignore my messes please
Image anti slip tape ramp angle increased with axel flip. The anti slip paint additive seemed to be less effective.
New wire 110 and 12 volt by "new" counter.
My super glue fix for where I broke my led sting of lights. I will tack it down later.
Image new string of LED's lights for counter.
Image my "conduit"
Moved AC and plastic storage drawers.
And my exterior antenna hook up!
Padilen
Its sort of mine!
Postby Padilen » Mon Sep 19, 2016 10:24 am
Ugly but cheap foot stool/storage. All from scraps and looks it too.
Storage box that was going to be for rake and shovel,but??? From free wood scraps. And free paint.Image
Padilen
Postby Padilen » Mon Sep 19, 2016 3:49 pm
Bathroom fan and lights. I just need a clever way of attaching the fan wires. The computer fan is suppose to be water resistant, but I don't see any conformal coating like ad stated.
Padilen
Postby flboy » Mon Sep 19, 2016 4:15 pm
Padilen wrote:Bathroom fan and lights. I just need a clever way of attaching the fan wires. The computer fan is suppose to be water resistant, but I don't see any conformal coating like ad stated.
Looks like you have been busy. Please tell me that fan in the shower is 12VDC. :shock:
Don (Flboy)
flboy
Images: 378
Postby flboy » Mon Sep 19, 2016 4:23 pm
I think you could get some white heat shrink tubing to enclose the wires and to make the wire blend in with the white background and then get some adhesive backed cable tie mounts like the ones in the link to hold the cable down with tie wraps.
https://www.amazon.com/Uxcell-Plastic-A ... Tie+Mounts
Don (Flboy)
flboy
Images: 378
