A toyhauler cargo conversion
Re: A toyhauler cargo conversion
Postby hankaye » Mon Feb 11, 2013 10:40 pm
pvangel, Howdy;
The shower was only a suggestion,...
Where are you going to vent the hydrogen fumes from
your battery while it's charging ???
hank
hankaye
Postby pvangel » Tue Feb 12, 2013 10:57 am
I made a vent in the battery box, and will seal up the bigger holes.
This will go through the wall,
pvangel
Postby hankaye » Tue Feb 12, 2013 3:23 pm
pvangel, Howdy;
Kool beans dude ... :thumbsup:
hank
hankaye
Postby pvangel » Tue Feb 12, 2013 8:05 pm
I was able to clean up the rest of the wiring tonight except the water pump which I have to mount first so did a quick layout check.
16 gallon water tank in place and my Honda EU 1000.
I did reinforce the floor of the cabinet before installing to make sure it held the weight I was planning on putting in there, cooler just fits!
And I wanted to be able to put the boots in there as well.
Now I can mount the tank and pump.
pvangel
Postby pvangel » Wed Feb 13, 2013 8:34 pm
So...back to the floor, cut in the first piece of Etrack so it ends up flush to the floor tile.
Looks good!
I cut in the wheel chock holders, have to clean up the wholes but should work well.
pvangel
Postby pvangel » Thu Feb 14, 2013 7:01 pm
For those of you waiting for waiting for my daily update....It's friggen Valentines day and Sister Mary Margaret (my lovely wife of 30 years(at this point it is a life sentence)) deserves some attention too!
I think she might be jealous of the time spent on the trailer so I have to be good tonight.
Stay tuned tomorrow...same bat time and same bat channel
pvangel
Postby hankaye » Thu Feb 14, 2013 11:30 pm
pvangel, Howdy;
I'm just suprised you checked-in ...
hank
hankaye
Postby pvangel » Fri Feb 15, 2013 6:15 pm
Hank, Just didn't want you guys to think I was slacking....
No work this weekend so gonna get a bunch done!
pvangel
Postby dudleydoright » Fri Feb 15, 2013 8:10 pm
hey pvangel,
I'm married to her sister (sister Margaret Mary and we've been married 48 years) :beer: :beer: :beer:
Mike
GONE FISHIN'
ddr
dudleydoright
Postby pvangel » Fri Feb 15, 2013 8:48 pm
Mike, I drink to you as well! :beer: :beer: :beer: and share your pain...
Just kidding... my wife is the most wonderful person in the world and I have had 30 years of marital bliss!!!!
I have come a long way!
I wanted the holes to be cleaner for the wheel chocks and found I could drill by hand and get a nice clean cut.
and then flipped it over to trim the hole,
And found this, I LIKE IT!!!
Pain in the butttt fitting it all but everything will line up nicely I think. Have to stop because each piece needs to be bolted down before I can do final installation.
pvangel
Postby pvangel » Sun Feb 17, 2013 7:22 pm
Floor is in and DONE! All the wheel chocks and etrack are bolted down.
pvangel
Postby pvangel » Sun Feb 17, 2013 8:18 pm
Even though it was cold and we had 30 mph winds here today I manned up and mounted the battery vent, power cord, water fill doors, and 120 outlet on the exterior so I could tie everything into the trailer.
I tried to hook up the battery vent( and water fill) but the 1-1/4" tubing I bought was way too stiff even after heating it up it just won't bend.
I mounted the water pump above the tank to save space but it vibrated like a coin operated bed in Reno because it was centered between the studs.
So I moved it down and close to the stud, seemed much better.
pvangel
Postby pvangel » Sun Feb 17, 2013 8:35 pm
I have to say this is the best $99 I have spent on the trailer so far, I love it!
pvangel
Postby pvangel » Sun Feb 17, 2013 10:21 pm
Also.... I was able to test the converter with everything running at once, 8 lights, Fantastic fan, water pump all at the same time. According to the manual a alarm will sound if you exceed the DC output of the unit, which I did not calculate but guessed....I guess right?
pvangel
Postby hankaye » Sun Feb 17, 2013 10:48 pm
pvangel, Howdy;
Have ya thought about turning your battery 90*, with the vent opening .... ;)
hank
hankaye
