Photo of the A/C rack installed.
The funky piece of aluminum is an angle secured to both rack and the A/C. There are also a couple of screws from the side angles to the A/C "box". Be careful when ya' drill holes; don't want to hear any pffftt's.
I should have been smarter and welded a tab in place.
I wanted to spread out the load stress on the door. Not shown is a latch I used on the inside to take the sag load off the hinges when the door is closed. Pictures if I rember tomorrow. Two bolts that secure it are visible on the upper non hinged side of the door.
Microwave installed on its shelf with a cam lock strap to help hold it in place.
I put the fridge in it's place today; need to make a bracket to secure it. Maybe tomorrow.
The eagle eyed observer will note a change in the pex line to the hot water bypass valve. It's an old recycled valve and has a very slight drip I can not remedy. The trial repair called for cutting the pex and I used a sharkbite from the plumbing odds 'n' ends box. Tonight I got a brand new valve and that ease of removing the sharkbite will come in handy tomorrow.
