Not as cold last night low to mid 40's. No moisture issues.
But I didn't mention this before. I don't have the heat on until I go out. Except yesterday I had left it on low to help remove the moisture. This was reading when I went out.
This was after shower
This morning it was a little warmer but humidity was same as before shower.
70* and 70 humidity.
Now the leak- so I showered no leak. Went to use bathroom later, spotted water on floor
. So still investigating! I don't find a leak in water lines, all dry. I wondered last night if the seal for the toilet isn't sealing the shower pan. Allowing shower water under toilet, around toilet/holding tank base mount.
Used my bigger fan to circulate air and dry up under shower pan. I tried using the dehumidify setting on AC. It read 68* when I turned it on. Dropped temp to 64, immediately, I heard compressor shut off. So it was a fan only, not sure if it frosted coils. Turned it off.
Guess I had heat set to high, I was hot all night.
