Intro and title, “motobox that my wife would camp in”
Re: Intro and title, “motobox that my wife would camp in”
Postby hankaye » Sun Mar 21, 2021 9:44 am
Big Dave, Howdy;
Something like this is the industry standard.
https://www.amazon.com/Valterra-A10-331 ... B00ON29N7C
Can also visit Valterra's site, or shop around for pricing...
hank
hankaye
Postby BigDave_185 » Sun Mar 21, 2021 9:47 am
And it needs vented outside correct? So I could put it in the floor?
BigDave_185
Postby hankaye » Sun Mar 21, 2021 9:51 am
Big Dave, Howdy;
Hydrogen is lighter then air so it would need to be above the top of the container, porting out board.
OR install a fan to pull it down-n-out. Your trailer, your choice.
hank
hankaye
Postby BigDave_185 » Sun Mar 21, 2021 9:03 pm
Anyone think I should add more battery to this?
I think I’m going to build a battery box in the floor above the axles,
I also want to order this to charge them?
Power Inverter 2000w DC 12V to AC 120V Modified Sine Wave Inverter with LCD Display Remote Control 3AC Outlets Dual 2.4A USB Ports for Car RV Truck Boat by VOLTWORKS https://www.amazon.com/dp/B07R511SR8/re ... M2AJ5MAA7V
BigDave_185
Postby flboy » Sun Mar 21, 2021 9:21 pm
BigDave, maybe I misunderstood, but this is not for charging the batteries at all. This is an inverter to take 12vdc from batteries to make 110VAC power. This is a modified sinewave so I would not recommend it for inductive loads or expensive or sensitive electronics. You want a pure sinewave inverter for that.
You need a converter to charge the batteries which takes 110VAC and makes 12dc power to run 12vdc appliances and lighting. The converters typically have a built in battery charger to charge the batteries.
Don (Flboy)
https://youtu.be/6_-8cVdWUIA
https://youtu.be/MUcMM86LA2g
flboy
Images: 378
Postby BigDave_185 » Sun Mar 21, 2021 9:30 pm
I was under the impression I needed both of these to function in the trailer.
WFCO WF8955PECB Black 55 Amps Power Center Converter Charger https://www.amazon.com/dp/B004BC59S6/re ... 6Y71KFZRG5
I have to admit. The power side of all of this stuff has me lost. I can frame and build anything, I can handle plumbing and so forth but add sparks and I get lost
BigDave_185
Postby flboy » Mon Mar 22, 2021 6:43 am
Yes, the WFCO is what you need to charge the batteries and etc. It is a good all in one for your DC and AC wiring with fuses and breakers.
Google the difference between a pure sinewave inverter and a modified sine wave inverter.You may want to get a pure sinewave inverter.
Here is a good link from Renogy:
https://www.renogy.com/blog/-benefits-o ... 60QAvD_BwE
Good luck with the wiring. It is not that hard and should be straightforward with the WFCO panel.
Don (Flboy)
flboy
Images: 378
Postby BigDave_185 » Mon Mar 22, 2021 7:23 am
flboy wrote:Yes, the WFCO is what you need to charge the batteries and etc. It is a good all in one for your DC and AC wiring with fuses and breakers.
I guess before I got to deep into that link solar, I’m not adding solar to this right away, am I in need of the inverter T this point?
I thought the inverter was to take the battery output and change it from 12v to 120v for use to power the appliances and say.. phone chargers?
BigDave_185
Postby BigDave_185 » Mon Mar 22, 2021 7:29 am
This is the right style of inverter, I don’t see a medical device this year but reading makes for sound advice for the fridge or a Tv at some point on a wall to watch a movie
Renogy 2000W 12V Pure Sine Wave Battery Converter, ETL Listed with Built-in 5V/2.1A USB port,and AC Hardwire Port Solar Power Inverter https://www.amazon.com/dp/B07H9SXV61/re ... HBD1?psc=1
BigDave_185
Postby aggie79 » Mon Mar 22, 2021 2:17 pm
Fantastic job on the lifting bed! I envy your metal fabrication skills.
Regarding the power converters, having used both WFCO and Progressive Dynamics, I prefer the latter (PD). Here's a link: https://www.progressivedyn.com/rv/power-centers/.
Postby BigDave_185 » Mon Mar 22, 2021 2:32 pm
aggie79 wrote:Fantastic job on the lifting bed! I envy your metal fabrication skills.
What’s the difference?
BigDave_185
Postby BigDave_185 » Mon Mar 22, 2021 3:30 pm
At this point I just want someone to tell me what to buy. Not looking for the top of the lien stuff but mid grade, I like simple these days
BigDave_185
Postby flboy » Mon Mar 22, 2021 6:06 pm
I have had neither, so I cannot comment. I have hooked them up for a few folks.. much the same in that regard and in function. I am sure either will work just fine for intended purpose.
Don (Flboy)
flboy
Images: 378
Postby BigDave_185 » Tue Mar 23, 2021 7:38 am
flboy wrote:I have had neither, so I cannot comment. I have hooked them up for a few folks.. much the same in that regard and in function. I am sure either will work just fine for intended purpose.
I think I’ll just order the pure sine and the one I first linked. Go from there
Or move on to framing walls and start plumbing for shower and toilet
BigDave_185
Postby BigDave_185 » Tue Mar 23, 2021 9:21 pm
Not the amount of progress I wanted since I didn’t order enough lugs.... but I’ll continue on Thursday with my 4guage positive and negative wires,
I have had some question regarding the goal or plan.
To be honest, seat of my pants comes to mind.
But
Here is what I have:
https://www.etrailer.com/RV-Lighting/Op ... ILL34.html
I ordered 6 of them. Installed one so far.
The fantastic fan also to pull some stinky kid smell out.
A few wall outlets to charge phones or other small electronics.
Water pump no idea ?
Instant water heater unit from Amazon
Camplux Pro 1.58 GPM Tankless Propane Water Heater, Outdoor Propane Gas Water Heater with Portable Handle, Portable Gas Water Heater for Camping,Cabins,White https://www.amazon.com/dp/B07TP8W2B7/re ... V14QZ0DBAS
Other wise I haven’t figured out fridge option, I’d like to get a dual fridge out of another trailer. The one I pulled last year has some major plastic interior issues I don’t want to deal with, I think my kids threw baseballs at it honestly.
I would like to plug in at a camp site if I can, I plan on a generator in the future, but otherwise rely on the battery’s for two day trips
BigDave_185
