FOR SALE 6x12 cargo conversion WITH SLIDEOUT FOR SALE
Postby madrider » Sun Apr 11, 2010 9:11 pm
michiganflipper wrote:Image
here is the back of trailer
Cool Idea, but where does the A/C drain to?
madrider
Images: 6
Postby 8ball_99 » Mon Apr 12, 2010 8:47 am
I have a couple of that same brand AC. One is mounted in the all of my Fish room 'Hard to explain' They have a small hole in the bottom you can connect a line to for them to drain. Its just a hols so you will have to drill and add a fitting. Or you can just stick a piece of hose in the hole haha.
8ball_99
Postby rebapuck » Tue Apr 13, 2010 9:58 am
And a broom closet!!!
It's a beauty. I like that you have decent counterspace in the kitchen. I see alot of build pix without that.
Maybe warm up your floors with those interlocking floormats that are about 1/2" thick foam/rubber?
Judy
1966 VW camper
1967 VW singlecab
rebapuck
Postby michiganflipper » Tue Apr 13, 2010 4:38 pm
Iwas just look at some at home depot for the same ideal
michiganflipper
Postby michiganflipper » Sat Apr 17, 2010 8:22 am
going to be on the right as soon as I can find something to mount there that won't leak
michiganflipper
Postby michiganflipper » Wed May 05, 2010 4:26 pm
BC Dave wrote:Nice workmanship on all the wood work; it comes together nicely.
Questions; I perused your online pics.
whats your total trailer weight like with all the woodwork and appliances installed? I think I added 300 lbs; which surprised me
Cheers D
just had it weighed today and it now weighs 2380 so i'm gessing about a 1000 lbs i've added
michiganflipper
Postby michiganflipper » Wed Jun 23, 2010 9:06 pm
new brakes instaled
old hub
new drum,bearing and seal
spindle bfore cleaning
spindle all cleaned up
easy grease spindle and brake mounting plate
new brakes
new hub instaled
new tires and rims went from 205/75/15 to 225/75/15 raised trailer about 1 1/2 inches
michiganflipper
Postby michiganflipper » Sun Oct 03, 2010 4:28 pm
here is the front of the new add a room
Imageadd a room by michiganflipper, on Flickr
side veiw
michiganflipper
Postby dudleydoright » Sat Oct 30, 2010 3:18 pm
just curious, how has the a/c worked with the back doors closed?
GONE FISHIN'
ddr
dudleydoright
Postby michiganflipper » Sun Oct 31, 2010 5:11 pm
I ended up putting a vent in the roof because alot of hot air was being traped around the ceiling other then that the ac works very good
michiganflipper
Postby michiganflipper » Sun Feb 06, 2011 6:39 pm
check out my slide out build
michiganflipper
Postby LShrew » Mon Feb 07, 2011 12:02 am
I just used a funnel and length of tubing to make an easy drain for the AC.
LShrew
Images: 11
Postby tod » Mon Feb 07, 2011 10:11 am
Great pictures of the brake upgrade. I did not realize it was that straight forward.
Thanks,
Tod
tod
Re: 6x12 enclosed conversion
Postby michiganflipper » Wed Jan 23, 2013 8:37 pm
I can see that all of my older :pictures: :pictures: that where posted on here via webshot does not work but you can still check them out at my web site at Great Lakes Cargo Club
michiganflipper
Postby Bkcreation34 » Thu Jan 24, 2013 2:37 pm
Hey I like the outside screen room where did you find that at and do you mind telling us was it expensive and did you have to do anything different on the outside to make it stay on the CT. It looks very cool and adds so much more room to it. A great Kitchen add on I would think.
Bkcreation34
