I'm looking into replacing my side window unit with a portable room one vented through the floor.
http://www.amazon.com/gp/product/B000PGQ8YQNewAir AC-12000E 12,000 BTU Portable Air Conditioner With R410A Refrigerant
I've been taking the widow unit in and out dependent on moving trailer and storms.
I'm thinking this room unit with a specific place and floor vented would work for me.
Wolfscout wrote:Copying my post from another thread to keep it here for my build.I'm looking into replacing my side window unit with a portable room one vented through the floor.
A dual-hose portable air conditioner, such as the Friedrich P12B, works by taking in air from the outside through one hose and using that air to cool the unit. The hot exhaust air is then expelled through the second hose. This process does not create negative pressure inside the room being cooled. However, there is a tradeoff. Dual-hose units use warmer, unconditioned air to cool their compressors, which results in slightly less efficiency. They also employ two internal fans, which can mean slightly higher energy usage. At this time, we have not seen conclusive evidence that either solution, single- vs. dual-hose, is better than the other when all factors are considered.
Wolfscout wrote:I did some checking around after I read your posts and links.
I found this link http://www.sylvane.com/learning-center/portable-ac-faq.html#hosedesignA dual-hose portable air conditioner, such as the Friedrich P12B, works by taking in air from the outside through one hose and using that air to cool the unit. The hot exhaust air is then expelled through the second hose. This process does not create negative pressure inside the room being cooled. However, there is a tradeoff. Dual-hose units use warmer, unconditioned air to cool their compressors, which results in slightly less efficiency. They also employ two internal fans, which can mean slightly higher energy usage. At this time, we have not seen conclusive evidence that either solution, single- vs. dual-hose, is better than the other when all factors are considered.
