Taco Jeff wrote:lrrowe wrote:Taco Jeff,
Nice looking rig.
I like the ground clearance. I assume you used a straight axle.
Hope my someday will look that sharp.
Bob
Thank you very much.
I used a 3500 lb axle for the big brakes and air bags for the adjustability.
I lower the trailer when we get to camp.
Let me know if I can help you with any of your ideas.
Jeff
Thanks Jeff, I sure will not be afraid to ask questions when I start. But first let me ask this. I am traveling a considerable distance next month to look at some highly recommended CT models. I will not order right then on the spot. I will go away and think about what I saw.
But aren't all the axles being offered 3500lb units? And did you install the air bags yourself or where they a factory item? I like the idea of being able to lower the trailer. I too anticipate going off the beaten track (not exactly off road) and clearance will be an important factor to consider.
I see as many posts which infer that the builder is not getting brakes added on a single axle unit. What motivated you to go for them? And you mention the brake size as 10 inches. Is that important to know? In other words, are there brake size options to consider?
Bob
