here we go again 14+7 V
Re: here we go again 14+7 V
Postby Tx River Rat » Tue Mar 11, 2014 10:32 pm
Got a little done on the trailer ,kitchen cabinet and bathroom walls framed up
Counter top base cut.
Ron
Tx River Rat
2nd Teardrop Club
Postby RWH » Wed Mar 12, 2014 9:44 am
Lookin good :)
Cargo Trailer Conversion Toy Hauler Conversion
My Prospecting Videos Videos By Muddog Productions
RWH
Postby lrrowe » Wed Mar 12, 2014 2:43 pm
Tx River Rat wrote:Got a little done on the trailer ,kitchen cabinet and bathroom walls framed up
Ron
Ron, I assume you are going to build a slide out base for the oven/stove?
BTW, the CT is looking good.
Bob
Bob
lrrowe
Images: 439
Postby Tx River Rat » Wed Mar 12, 2014 3:21 pm
The door will fold out flat where you can slide the oven out and use it inside the trailer, it will be used outside most of the time. A 2 burner stove top will be installed for most of the inside cooking and coffee making.
Hot biscuits and gravy sure go good on the side of a mountain, I love this oven.
Thanks for the compliment .
When I get the cedar strips on the counter top and build the doors it should start looking better.
This is going to be a slow build ,I am going to try to keep it campable while adding to the inside.
Ron
Tx River Rat
2nd Teardrop Club
Postby Tx River Rat » Sun Mar 16, 2014 6:33 pm
cut a few cedar strips of different colors and did the counter top
now a lot of sanding then a finish applied should look good.
Ron
Tx River Rat
2nd Teardrop Club
Postby RWH » Tue Mar 18, 2014 10:48 pm
Those tops are going to look great.
RWH
Postby Tx River Rat » Thu Mar 27, 2014 9:00 am
Thanks RWH
Just about finished with counter top ,one more coat and it is on to the table.
Put up the rest of the paneling,using a cedar paneling.
Ron
Tx River Rat
2nd Teardrop Club
Postby Tx River Rat » Thu Apr 03, 2014 2:56 pm
Had a few hours loose so I started working on the over head cabinets ,Framing them up takes some figuring and time with the crowned ceiling.
But here we go
cut and install ply backing
put on the cedar paneling
Guess it is time to start thinking about some doors.
Ron
Tx River Rat
2nd Teardrop Club
Postby lrrowe » Thu Apr 03, 2014 5:31 pm
I love those rounded corners in the upper openings. I am anxious to see how you cut the doors for them.
Good job!
Bob
Bob
lrrowe
Images: 439
Postby Tx River Rat » Fri Apr 04, 2014 8:38 am
Bob
I really havent made my mind up on the doors yet. I am thinking of trying a door with the same shape as the opening hinged on top.
Any ideas would be appreciated.
Ron
Tx River Rat
2nd Teardrop Club
Postby lrrowe » Fri Apr 04, 2014 10:07 am
Nothing pops to mind right away, but as I see other ideas that you might be interested in, I will send you the link. I am always going back and looking at other ideas. I might be close to getting my CT (a used one) so I do need to come up with something.
If you hinge on top, won't you need some sort of mechanism to hold the door open? Otherwise it might be cumbersome to access everything with one hand. Maybe a magnet latch on the ceiling or some bracket that holds it open.
I saw one poster awhile back leave then open (i.e. no door at all) which I might consider for side cabinets (not kitchen type) for storage of frequently used camping/hunting items. It was very clean looking. But for kitchen food and supplies, I do believe you need doors.
On another topic, I see that you are using construction quality plywood for the cabinets and then covering them with thin veneer. I want to have the hickory look and this would be a lower cost alternative for me rather then buying 1/2 and 3/4 inch hickory plywood sheets. Use regular Big Box Store plywood and then order special hickory veneer in 1/8 or 1/4 inch thick.
Bob
Bob
lrrowe
Images: 439
Postby Tx River Rat » Fri Apr 04, 2014 10:45 am
Bob
I have a Casita with doors that hinge from the top and really like them ,it isnt a problem retrieving things and they always stay shut :D
Using the ply to frame with works well and it is much stronger.
I used 1/4 inch and framed with cedar.
Ron
Tx River Rat
2nd Teardrop Club
Postby lrrowe » Fri Apr 04, 2014 10:56 am
Great idea....and must cost less. Am definitely going to try and do this.
And hopefully, next week, I am able to drive to NC from VA and purchase a used 2013 7 x 14 so I can start all that I have on my "build" list.
Bob
Bob
lrrowe
Images: 439
Postby Tx River Rat » Fri Apr 04, 2014 10:59 am
Bob
The only bad problem with getting your trailer is not wanting to stop working on it.
Ron
Tx River Rat
2nd Teardrop Club
Postby Rainier70 » Fri Apr 04, 2014 8:16 pm
Your build is sure looking good. I love your countertop and cabinets.
Rainier70
Images: 244
