7'x22' Diamond Cargo Conversion
Re: 7'x22' Diamond Cargo Conversion
Postby 2500HHP » Fri Dec 05, 2014 5:59 pm
Got the rest of the ceiling mounted and trimmed out. Going to leave the v for now because I plan to build cabinets straight across where the last piece ends.
Anyone who's interested, below is the wood I used for the ceiling. It's light, cheap and lays nice with screws every 16".
2500HHP
Postby lrrowe » Fri Dec 05, 2014 9:56 pm
I do like this. I am taking the photo and label to HD and my local private supplier to see if I can get some.
Thanks Awedge.
PS. And I like the big head screw approach. I plan on doing something like that so I can remove the ceiling or wall covering should I ever need to get back there....say for rewiring, etc.
Bob
lrrowe
Images: 439
Postby 2500HHP » Sat Dec 06, 2014 2:30 am
lrrowe wrote:I do like this. I am taking the photo and label to HD and my local private supplier to see if I can get some.
Thanks Awedge.
Bob, The wood actually came from Home Depot so you should have no trouble finding it. The screws I used are 3/4" self tapping screws for attaching wire mesh, hence the larger head...food for thought. They lay just about flush once they're torqued down a bit.
Up next, cabinets in the nose!
2500HHP
Postby 2500HHP » Tue Dec 23, 2014 10:57 am
Well between working out of town and holiday stuff, managed to make some progress on the trailer.
First, I had a bed rail mount tool box laying around that fits great and the lip for the bed rail works perfect for the dist hitch mounts. So that got mounted.
Then, I found a guy who is about 2 min from me that makes cabinets, so I had him make me a cabinet face with doors. I mounted the switch panel yesterday am going to start wiring today. I already have the all the lighting terminated to two bus bars on the right side wall behind the cabinet. I think behind that first door on the right will be the "nerve center" for the trailer.
2500HHP
Postby MyYota85 » Fri Jan 02, 2015 12:16 pm
Nice build awedge, any complaints on the diamond cargo trailer? And u mentioned a shower have u decided where the tanks will go?
MyYota85
Postby jwhite » Fri Jan 02, 2015 5:09 pm
I really like carpet on the walls, I got lucky and found a whole roll of carpet at lowes being closed out it was the perfect color also. adds a really nice finished look on the inside.
8363266562
jwhite
Images: 46
Postby 2500HHP » Sat Jan 03, 2015 12:04 pm
MyYota85 wrote:Nice build awedge, any complaints on the diamond cargo trailer? And u mentioned a shower have u decided where the tanks will go?
Thanks yota, no the Diamond appears pretty solid other than a few gaps between the floors and the walls after I removed the bottom trim. I would also like to see more weldment where the ribs meet the ceiling, but other than that I am happy with it.
I plan to mount the tanks underneath the trailer. There is approx 18" between floor crossmembers so I'm sure I can find a tank that will fit there. I also plan on doing an axle flip at some point so ground clearance won't be an issue either.
2500HHP
