McDave wrote:Hey m.colley, and flboy,
There are all kinds of faux diamond plate out there. Plastic sheets, vinyl etc.
https://www.etsy.com/listing/201741296/ ... aQodgVcHmw
http://www.overstock.com/Home-Garden/Fa ... oduct.html
http://www.specialty-graphics.com/rtape ... aQodQXgJFw
McDave
PS. I have built doors by just cutting a piece of plywood (3/8?) to the final size needed, then just apply trim or moulding to outside face to look like rails and styles. I like to make my own trim from 1" x ? and running the 8' length thru the router table with an "Ogee edge bit". You can do 1 edge or both and obtain different styles just by changing the depth of the bit. You can mass produce it and stain or paint it in 8' lengths and then just cut and miter as required. Baseboards, chair rails, crown, door frame trim etc. You really don't need "clear" or "select" lumber but dried would be best so it doesn't warp or twist.
flboy wrote:Nice work! Looking good.
Those are nice, real nice. You weren't kidding about having cabinet making skills. That is a time consuming project, but I'd have to say it was worth it. Well done. Take the rest of the day off.
McDave
hankaye wrote:m.colley, Howdy;
Tidy lookin' set of cabinets indeed. ,
hank
flboy wrote:Nice looking cabinets and etc.! You have made a lot of progress.
Have you decided on a counter top yet? What do you plan to use? I am thinking about using 3/4" plywood and gluing on the Formica... That would be another first for me... so I am not sure how that will turn out.
