7x16 V-nose conversion - Tennessee
Re: 7x16 V-nose conversion - Tennessee
Postby Vspec » Wed May 17, 2017 9:09 am
What length E track did you use?
Vspec
Postby ffemtp » Wed May 17, 2017 10:20 am
60" - a Queen size bed is 60"x80", so this worked perfectly for both dimensions. I also used the old 3/4" plywood that was the flooring and cut it into (4) 20"x60" pieces. Then I pieced two of them together with a piano hinge. I did this with both pair. I also planned the length and width of the area where the water tank is to store those four pieces when the bed is "put up". It worked out well!
ffemtp
