McDave wrote:I don't suppose there were any type directions provided with that screen, no of course not. So it is like a Chinese puzzle. I hate those. So all I can think of is to make carefully placed cuts to accommodate the cables, plus you may need to make one to get past the pulley on each side. Now the question becomes how to keep the screen from unravelling where the cuts were made. I know there is a product for mending screen, Iron on I believe. That gave me an idea for the cable relief. If you made a vertical cut just long enough from the top so the cable could travel freely through it's range, you could then iron on or sew a boarder or hem like the one at the top of the screen to keep the cut edges from unravelling and also would keep bugs out. So the cut would have a right hem, and a left hem that butt up next to each other but allow the cable to move between. I hope that made sense. I don't know what to call that material, webbing maybe? Anyways, that's the best I can think of.
Good Luck!
https://www.amazon.com/Window-Screen-Re ... B00SKJT81U
McDave
hankaye wrote:SilverStreaker, Howdy;
If you have an electric soldering gun/iron, then you can use that to "cut" the fabric
and prevent it from wanting to continue separating. Smells nasty so make sure you have
good ventilation. You can use some Velcro to hem the edges so that you can open
and close it to reduce the ariel attacks.
hank
beachguy005 wrote:One other idea to consider is to mount the screen on the ceiling forward of the cable lift instead aft of it. You'll hardly lose any space.
duncanshannon wrote:looks great! Looking forward to watching the build!
duncanshannon wrote:Love how you are already using it! Are you designing the inside as you go or do you have a plan?
SilverStreaker wrote:duncanshannon wrote:Love how you are already using it! Are you designing the inside as you go or do you have a plan?
Thanks! I started working on a design but it just wasn't coming together. So, I decide to just start using it and adapt it as the usage dictates. For example, we have two tandem kayaks and originally I planned on hanging them on the wall which will work great while towing the CT but not so much when we're ready to sleep. Some camping spots it would be fine to throw the kayaks outside over night but not everywhere. Now I'm looking to get ladder racks for roof and the kayaks will ride up there. I can also run a cable around the racks and through the scupper holes to lock them up.
Another thing we wanted to take with us is all 4 of our bikes and the best solution I came up with was using a bike rack which I could screw down to the deck while in transit and than set it outside and lock the bikes up during the night. I also have a heavy canvas tarp which covers them up perfectly.
I originally had the rack set towards the front of the trailer as shown in the picture but after our first real outing I decide to move it all the way to the back for better weight distribution.
I still use a few straps to secure the bikes but nothing like what would have been needed without the rack.
mradair59 wrote:SilverStreaker, did you find some ladder racks for you trailer? If so, what kind?
I have been looking, but dang they are expensive.
Thanks
