Sounds good. If the space heater can keep up during your coldest days then you're all set. I haven't had good luck with space heaters lasting more than one season though, so you may want to have a spare handy.
The reason I asked was some heat sources would require greater diligence with ventilation. Electric is the least concern, no CO emissions. I think if you're ventilating enough to compensate for people and animals expirated CO2 and aspirated O2 you'll be fine.
Fire detector, fire extinguisher, an air quality alarm ( CO2, gas, etc ), reliable emergency light that you can find in a blind dark, more than one exit. All things I would consider as mandatory. A cat sleeping in front of the space heater could rest it's tail up close, any long hair may reach an element, something about a hot tin roof, etc.
Also, if you would like some reading material, I found a message board that ski bums use to discuss sleeping in a car during the winter. You'll be facing similar challenges. Also most of them are working with a near zero budget, so some of the solutions they come up with are handy and affordable.
http://www.tetongravity.com/forums/show ... the-winter
