Need advice on my new 8.5x20
Re: Need advice on my new 8.5x20
Postby lrrowe » Fri Oct 31, 2014 7:13 am
A shower will be my December project. My plans are to go with a 24 x 32 base. I may purchase it or make it myself. I do not see making one too hard. There are some interesting projects listed in this forum section. I will probably raise the base to accommadte a single 90 degree flapper drain and (1) at first just drain into a 5 gal jug and (2) later look at a grey water holding tank. One option for me is to build the tank out of 6 in drain pipe I have laying around. The design will come in December.
Inside the Shower area I will put a portable pottie for my wife's midnight trips to the bathroom. If I am not at a campground with facilities, I will use a shower tepee for the toilet bucket using the 5 gal, plastic bag and kitty litter approach. I do not want that stuff in the CT. It should work out find.
But then again, with your sq footage, you can add much more to the interior.
Use the Search feature for this section using the right words for what you want to research. There are many bathroom projects from the past.
Good luck.
Bob
lrrowe
Images: 439
