Would you believe I am running the AC off the batteries right now. It draws about 47 Amp running and Solar is replacing about 10A as I go with the sun low in the Sky at 9:09AM. I can see where I will be able to pull off in a rest stop on a sunny day and crank up the AC and have lunch and take a nap without any generator. This is why I built in the smaller AC that cools the trailer fine and uses lower power. I love it... I don't think I have enough battery capacity to run overnight.. but definitely on a sunny afternoon... when it is the hottest..
