H&H 14x7 V nose conversion in MN
Re: H&H 14x7 V nose conversion in MN
Postby nunrleft » Mon Apr 27, 2015 10:53 pm
Today I was able to get my plumbing finished (except for wiring the pump).
And I got the cabinet return made. This will be the home of my battery cut off switch, a 12v receptacle, a 110v receptacle, a light switch and my pump switch.
nunrleft
Postby professorkx » Tue Apr 28, 2015 4:26 pm
Is your counter butcher block? I like the look...
professorkx
Postby desertrat222 » Tue Apr 28, 2015 5:13 pm
So mad i bought a white fridge, that looks sharp!
desertrat222
Postby nunrleft » Tue Apr 28, 2015 11:23 pm
professorkx wrote:Is your counter butcher block? I like the look...
Yes, Birch butcher block, but only about 1 1/8" thick. Lighter than 3/4" particle board with laminate. We'll be oiling it so it will darken up a bit.
Got my cabinet return and wiring complete today.
Also got my LED counter top lights installed.
nunrleft
Postby Gunman9 » Wed Apr 29, 2015 8:54 am
Did you run a vent for the mini fridge or is that necessary? Trying to figure out if I need to do this in mine when it arrives.
Gunman9
Postby professorkx » Wed Apr 29, 2015 3:39 pm
Gunman9 wrote:Did you run a vent for the mini fridge or is that necessary? Trying to figure out if I need to do this in mine when it arrives.
I didn't run a vent for mine...we will see if it will be a problem. However, I do have about 3/4" around the fridge, so heat can escape, and since heat rises, I don't expect a problem...
professorkx
Postby nunrleft » Wed Apr 29, 2015 6:53 pm
No specific vent for the fridge. I shouldn't need one since the area under the left base cabinet is completely open. If I do I have a hole on the floor near the fridge that I can open (the original electrical service door that the dealer installed).
This afternoon I installed the garage area lights. Two 10 foot strips of LEDs. Housing is made from soffit J channel and florescent light covers that I cut down on the table saw:
I also got the heat strip installed in the air conditioner and the lower housing mounted. Finished up the power center cabinet also.
nunrleft
Postby Gunman9 » Wed Apr 29, 2015 7:04 pm
I know you said you did your plumbing. Did you use a kit like this:
http://www.ebay.com/itm/25-Gallon-Fresh ... 3d&vxp=mtr
Or buy all your parts separate. I have never installed an rv style water system. I got the bar sink and faucet and that's it. Would this be a good buy considering the price?
Gunman9
Postby Jiffypop207 » Wed Apr 29, 2015 8:11 pm
That lighting is sharp. I have the same led strips already. And chance for a close-up of the j molding you used?
Adam
Jiffypop207
Postby funengineer » Thu Apr 30, 2015 7:19 am
Excellent idea to house the LED strips nunrleft. Mind sharing your source for the LED strips? I'd like to see details of the install also.
funengineer
Postby nunrleft » Thu Apr 30, 2015 8:34 am
Gunman9 wrote:I know you said you did your plumbing. Did you use a kit like this:
I believe it was cheaper for me to buy everything separate. Look at the first few pages of this thread, I listed prices for the parts I bought.
nunrleft
Postby nunrleft » Thu Apr 30, 2015 7:19 pm
J channel used : http://www.homedepot.com/p/Gibraltar-Bu ... /202092944
LED supplier is http://www.glowhut.com The LEDs come with an adhesive back but I've found they don't stick very well. So I supplement the adhesion with silicone caulk Not much to installation. Stick them to the wall, black to negative, red to switched positive.
nunrleft
Postby funengineer » Thu Apr 30, 2015 7:20 pm
Thanks for the info.
funengineer
Postby Gunman9 » Thu Apr 30, 2015 8:25 pm
I was looking at the same water pump you got. The LEDs are really nice to man like the look of them. I'd do something like that but the factory install 2 - 4ft LED lights in the trailer but if it's not enough im gonna go your rout. Did you just bend the J Channel back after screwing it into the wall?
Gunman9
Postby nunrleft » Thu Apr 30, 2015 8:27 pm
The light cover panel gets slid in through the end of the J channel.
nunrleft
