sodatrain wrote:Thanks guys!
Whew... head hurts. Just searched and read for a couple hours... trying to figure out how to design my electrical system.
Here is what I have so far... can you please review and let me know what's wrong or doesn't make sense? I created it using Google Drawings, so happy to "share" it and give access for editing... just PM me your email!
Goals:
1) Use shore power OR generator to power the AC, possibly a TV/Xbox, and to charge the batteries.
2) Have limited 120v for an outlet or two for things like laptop driven by the 12v batteries. I have a car inverter and may just use that.
3) Design with solar in mind in the future.
I have questions still.... but let's see how I'm doing with my understanding so far. Also, I believe I can use a PD4045 for the 120v/12v panel and converter right? Or buy separate components?
sodatrain wrote:Hey Folks-
I'm new to the site and have been reading/lurking for a couple weeks now. I've waffled between buying a cargo van and as someone pointed out with a cargo trailer and the F-150 I drive, I can disconnect the trailer and drive around w/o it as desired. It also solves the problem of storing/paying for/insuring my truck while in the van.
Backing up a bit...I'm keenly interested in trying out a different way of life that sheds the rat race - but need to co-exist with it for a while (kids, alimony etc).
I'm in the planning phase and am currently thinking of taking next summer (2018) off and spending a few months giving it a try. I'm strongly leaning Cargo Trailer Conversion and am working on dialing in the trailer size, features etc. based on price/quality etc.
Current thought is 7x12 Single Axle with 7' interior height (I'm 6'6" 300lbs) with v-nose.
Couple questions I'd love opinions on!
- Rear ramp or barn doors. I think I like the idea of doors but almost everyone seems to have the ramp. I have no "toys" per se to haul. Seems easier to have the doors and maybe a smaller footprint to open/operate the doors?
- 7' wide or 6' wide. If I go 6' wide I can get a Wells Cargo locally in Single Axel but if I want 7' I'll probably end up getting it somewhere (Continental Cargo) else as it seems there aren't a lot of 7' wide in single axle - and I'm trying to keep the cost down. Looking at 7' wide to have a decent size murphy bed on it's side near the back. I also want to be able to fold the bed up and slide my fat bike in. Probably a fold-down table on the back/underside of the Murphy. Would love a bench sort of design opposite it to use in tandem with the fold down table... and accommodate #3 below Example of a murphy bed / bench setup that seems pretty close
- I'd like to have some form of bunks (perhaps fold up and opposite the murphy bed for my two kids to join me at times. This wouldn't get used a ton but having a space for them is important. Any ideas on how to accommodate this?
- If I'm going to try it out for 3-4 month (summer) is it worth getting solar now or should I see how it goes? I don't see shore power as part of the plan.
- I def want some comfortable sitting/desk area.
- Are electric brakes enough or do you really want self-adjusting brakes? I've seen reference to self-adjusting several times. Asked two people about em and they scratched their heads.
- Thinking the usall spring axel w/drop is fine - maybe get a kit to lift it up.
Other bits:
- Plan to be generally in the western US. Hope to mountain bike. Hike. sit in the woods. read. maybe finally start meditating regularly. I don't expect to be trying to sleep in the city much but surely some.
Deff will remove the plywood and insulate the walls, ceiling, and floor. TBD On how much. At least 1" everywhere if not more.- Trying to keep it pretty basic overall. Bed, storage, water jug mounted above a bowl for a sink, some sort of cooking surface (propane camp stove?), some sort of toilet. Laptop for entertainment and possibly work.
- Probably will order it with two roof vents (let them cut thru the ceiling) and put an AC on one (I don't like hot)
- Extended tongue, side door with RV handle
- A few windows - maybe even a concessions window.
- Stabilizers
Enough for now!
Thanks in advance for any ideas!
dbuettner wrote:I also ordered from the same company and am hoping to pickup my 7x14 sa from continental cargo in Oregon in a couple weeks.
I cheated and ordered the 30 amp electric and insulated ceiling with finished panels. I've seen the factory unit like this and it looks great. I opted for the single axel as I also don't plan to carry much and weight is important. I'll post pics later, Thanks for all of your helpful and informative posts.
flboy wrote:
No need for a transfer switch between the Generator and the Shore power. They are mutually exclusive if they plug into the same input to the CTC.
flboy wrote:This is how my CTC is wired... just for some ideas... This could be done with an all in one panel... but you'd still need another panel for the transfer between Shore/Gen and Inverter... That would come after the all in one.
flboy wrote: I did mine as separate components (breaker panels, converter/charger, DC distribution) for "repair" reasons.... Converter/charger is the most likely module to fail since it contains all the electronics.... I can replace that piece without unhooking everything else (only 4 wires) for half the price compared to if I had to replace the whole all in one and unhook.hookup all the circuits. I am always thinking about servicing things later... comes from my days as a Field Engineer... makes a difference how quickly you can perform a repair on the ramp. Now hopefully things never break.. but sooner or later, they will and they always fail at the worst times.. Just been my experience anyhow.
flboy wrote:BTW.. if you intend to only use the inverter for a few little things like you have drawn and do not want inverter power available on various outlets... then what you have drawn should work... just get rid of the transfer switch and use one outlet into the CTC for AC power.
flboy wrote:You are welcome. What you have drawn for what you want to do will work fine and last a long time.
I mentioned the other panel if you were to use an inverter to feed the same outlets as the Shore or Gen.... Not needed in your setup.
Good luck with your build!
sodatrain wrote:Working on running wiring for the 12v. Bought some 50' and 100' spools. The stuff is an absolute mess from being wound around the spools. Are there good ways to deal with it??
Users browsing this forum: Google [Bot] and 3 guests
