The electric element I installed in the gas water heater is working and I have hot water... I hope the LP parts work.
All sanded and primed:
Painted with a high gloss enamel.
McDave wrote:When you turn the thermostat on, the pilot flame should extend to heat a thermocouple. That's the safety valve t-couple. After a few minutes, 2-4 min the safety valve should open and give you main flame. So, does pilot flame extend? Does it heat the t-couple bulb? You may need to adjust pilot angle or bulb location to get it in the extended pilot flame where it can get hottest. Also, there is a small chance that regulator is not set for LP. But being as this is and was a RV unit, I would think that's OK. If you need to, take your propane torch and heat the bulb from the safety valve, if it opens valve is probably OK, just not getting it hot. Take a quick look to see if there is a shut off valve on gas line to safety valve. If pilot does not extend when thermostat is turned on, probably a bad thermostat. Also, clocks can trip you up. If it has a timer make sure it is in manual position.
McDave
Padilen wrote:When you say fires right up are you lighting it or does it have an igniter?
For the oven I had a old never used stove. Because it didn't work! Retired RV guy said there was a known problem with it and took it to fix. Never saw it again
McDave wrote:Shoot me that Make and Model of oven. Its Magic Chef right? I may be able to help with that one.
McDave
PS. Some safety valves are diaphragm, not millivolt.
McDave wrote:Hmmmmm..... That doesn't sound quite right. The safety valve doesn't know the difference between bake/broil. Same burner, Yes? Broil is usually just infinite high so it won't cycle off at hi temp (+500). I don't think I have ever seen a T-stat with 2 different pilot settings. Also, safety valves are either good or not. I'm gonna have to think this one out, but we may be chasing the wrong ghost. I'll consult with Mr. Jameson later and see what we come up with. Gonna need a cigar or 2.
McDave
