Air mattress alternative
Re: Air mattress alternative
Postby droid_ca » Wed Dec 05, 2012 12:18 pm
droid_ca wrote:Just like everyone on here everybody's situation is different...as in my case I'd choose comfort over weight in regards to a good nights sleep but then I'm also looking for a more permanent solution (Tiny House) so for a little extra weigh I'm going to be going with a http://www.ebay.ca/itm/320574507615?ssP ... 1423.l2649 but then again like I said I'll be living in mine...But maybe others might want to do a similar idea
This was an idea I had for a previous one when weight wasn't an issue
“Fide Canem”
viewtopic.php?f=5&t=52816
droid_ca
Images: 176
Postby Xtremespeed » Sun Dec 16, 2012 12:11 am
Ok. I was in the Dallas area this weekend, so I tried a couple things out. The first was the previously mentioned Cabelas deluxe camp bed. This is not a self inflating pad. It is a piece of foam with a cover and has a board on one end to assist in rolling it up. The deluxe camp bed is way too soft and I immediately sunk to the bottom. It's also a little to short. This may be an option for children or people who weigh 150lb or less but not an adult over that in my opinion. The next thing I tried was the Cabelas Ultimate sleeping pad. This is a self inflating pad. The smallest one is 30" wide and 3" thick. They also have 36" and 50" widths. This is a very nice pad and very comfortable. I ended up taking 2 if these home. It is the first self inflating pad that I have tried that works well for me. The pad inflates pretty quickly to full thickness and even seems to require letting a little air out to achieve the best comfort. I did have to add air initially and leave it over night to allow the foam to expand after being tightly rolled from the factory, but after that, it deflated and inflated quickly and easily. These pads have the Cabelas name printed on them, but I noticed in the instructions that they are made by Alps Mountaineering. I was fully intending on buying the foam mattress from foambymail but I was still concerned about storing it. The pads are just a better option for me at this point I believe.
Xtremespeed
Postby revorunner » Sun Dec 16, 2012 11:03 am
Thanks for the update Xtremespeed. I hope they work out for you. :)
revorunner
Postby woytovich » Sun Dec 16, 2012 11:20 am
Inspired by your positive review of the Ultimate pad I went to the Cabelas site and found them on sale AND with free shipping. I bought a large one! Merry Christmas to me!
Thanks...
Mark
PS That is the pad that I originally meant to point you at by the way - I'm sorry I got you on the path to the Deluxe pad ("Deluxe"... "Ultimate"... I got confuzeled)
Mark - Metro New York
Toyota Land Cruisers: '66, '78 and '86
'03 Yukon XL, 2500/8.1 liter/8 lug + 18' 10k Car Trailer
M416 1/4 ton Military trailer - SOLD
5x8 Cargo/Camper - for sale soon
woytovich
Postby Xtremespeed » Sun Dec 16, 2012 1:00 pm
Not a problem. I really wanted to look at every option I could find. Didn't really intend to go back to the self inflating pads, but I am impressed with these and they should work out much better for my setup. I believe you will be impressed with it as well. Just remember to inflate the pad by adding air the first time, and leave the valves closed overnight the first time to allow the foam to expand fully. They are rolled so tight from the factory, the foam needs a little extra time to expand.
Xtremespeed
Postby roadinspector » Sun Dec 16, 2012 10:55 pm
Thanks for the update. You've been on a pretty extensive hunt for a cure. Sure hope this works for you.
Earnest
Dadgum it! I cut that board 5 times and it's still too short!
2001 quad-cab Dodge Cummins 3/4 ton camper special, 16x7x7 CT work in progress toyhauler, 01 HD Ultra Classic, 98 HD Heritage Softail, 88 HD 1200 Sportster. viewtopic.php?f=42&t=51510
roadinspector
Images: 127
Postby Xtremespeed » Mon Dec 17, 2012 8:35 am
I think these pads along with the memory foam topper will do it. We have a 4 night camping trip planned the weekend after Christmas, so we'll know for sure then.
Xtremespeed
Postby revorunner » Mon Dec 17, 2012 8:30 pm
Looking forward to your next update. :)
revorunner
Postby woytovich » Fri Dec 21, 2012 12:51 pm
FWIW I received my Cabelas Ultimate, large. It is a nice pad... on a concrete and tile floor I am supported pretty well. If I push up on an elbow I can feel the floor but otherwise, while laying down and flopping around, I'm not feeling through it. I weigh about 220lbs.
It feels more firm than I would like for sleeping generally. I liked the Ikea foam (not memory) mattress better but this is certainly more portable - I may look to add a 1" waffle foam pad on top of this. I won't be back sleeping in the trailer till spring so a real test will have to wait.
mark
woytovich
Postby Xtremespeed » Wed Jan 02, 2013 10:52 am
Update as promised. We just returned from a 5 day camping trip yesterday. The Cabelas ultimate sleeping pads made a great base for the memory foam mattress toppers. They took a little while to fully expand, and I think part of that may have been weather related. It was just below freezing when we got there. We slept on these for 4 nights and never had to go back and add any air. My ribs and hips never sank enough for me to feel the plywood base. In fact, I let a little air out a couple nights to try and soften the bed. My only complaint is that the bed was a little firmer than I would prefer, but the ultimate pads are thick enough that you can let some air out without sinking too far. I think if I had the room, I could probably gain a little comfort going to the foam mattress, but with my limited space, the Cabelas pads are doing a pretty good job and still have the ability to be rolled up and stored easily. Overall, I spent more money than I wanted to, but it got to the point of comfort being more important than the amount spent, within a reasonable range of course. If anyone is considering this setup, I am using a 2.5" 4LB density memory foam mattress topper from Sams Club on top of the Cabelas ultimate sleeping pads. If you can find one a little thicker without going to a higher density, I think it might help keep more of your weight from pressing down to the firmer Cabelas pad and make the bed a little softer. Just a thought.
Xtremespeed
Postby hankaye » Wed Jan 02, 2013 11:54 am
Xtremespeed, Howdy;
Xtremespeed wrote:Update as promised. We just returned from a 5 day camping trip yesterday. The Cabelas ultimate sleeping pads made a great base for the memory foam mattress toppers. They took a little while to fully expand, and I think part of that may have been weather related. It was just below freezing when we got there. We slept on these for 4 nights and never had to go back and add any air. My ribs and hips never sank enough for me to feel the plywood base. In fact, I let a little air out a couple nights to try and soften the bed. My only complaint is that the bed was a little firmer than I would prefer, but the ultimate pads are thick enough that you can let some air out without sinking too far. I think if I had the room, I could probably gain a little comfort going to the foam mattress, but with my limited space, the Cabelas pads are doing a pretty good job and still have the ability to be rolled up and stored easily. Overall, I spent more money than I wanted to, but it got to the point of comfort being more important than the amount spent, within a reasonable range of course. If anyone is considering this setup, I am using a 2.5" 4LB density memory foam mattress topper from Sams Club on top of the Cabelas ultimate sleeping pads. If you can find one a little thicker without going to a higher density, I think it might help keep more of your weight from pressing down to the firmer Cabelas pad and make the bed a little softer. Just a thought.
Just a thought and question;
Have you tried 'just' the memory foam to see how that might work for you?
I'd be of a mind to just have one thing to deal with opposed to 2. Thinkin' with my fingers again...
hank
hankaye
Postby Xtremespeed » Wed Jan 02, 2013 12:42 pm
Yes, we tried that first and for someone that doesn't weigh much it might work, especially if you use a higher density pad. It didn't work for us though. We could feel the plywood base and it was quite uncomfortable. That was the reason for adding the self inflating pads.
Xtremespeed
Postby revorunner » Wed Jan 02, 2013 7:07 pm
Thanks for the update Xtremespeed. :thumbsup:
revorunner
Postby hankaye » Wed Jan 02, 2013 8:24 pm
Xtremespeed, Howdy;
Thanks for the reply. As I'm in the same weight 'ballpark',
I felt it necessary to inquire... Ya never know till ya ask ...
hank
hankaye
Postby Xtremespeed » Thu Jan 03, 2013 2:11 am
Absolutely. Hope I helped out.
Xtremespeed
