pvangel wrote:After reading about the grounding of the 120v system and that it should not be grounded to the frame of the trailer( but some people have without an issue)
I'm Mike Sokol, the author of the NoShockZone articles on RV electrical safety at
http://www.noshockzone.org. I'm very curious about where you read that the 120v system of an RV should NOT be grounded to the frame? That's completely untrue per all RVIA and NEC guidelines. You MUST have a low-impedance connection from both the frame and the body of the RV to the safety ground contact of its shore power connection.
Also, ref generator "grounding", the NEC does not require that portable generators are grounded. However, I personally think it's a good idea and have designed a portable "grounding mat" that should work quite well for portable use. I'll publish plans on this design soon.
However, everyone should be aware that your portable generator itself may not have the Ground/Neutral bond that your RV's electrical system requires. That's because an RV's electrical system must keep its Neutral and Ground buss's separated internally. While many contractor generators include the G-N bond, typical suitcase generators, such as the Honda inverter series, definitely DO NOT have this internal G-N bond connection. This problem can be solved with simple G-N "kludge" plug in one of the generator's outlet, or simply wiring a short generator cable with an internal G-N bond. I have confirmed this with Honda, who state that they expect the G-N bond to be done externally, and a ground rod driven in the earth as required by local code.
Also, here's a quick way to test your RV for a hot-skin condition using a NCVT (Non Contact Voltage Tester) such as a Fluke VoltAlert.
http://www.youtube.com/watch?v=Y8h64X33aKgMore on this later, but I just want to make sure you guys all stay safe with your wiring.
